Help please Roland Cube CH 60 (Cube Chorus) schematic needed
  • Help please Roland Cube CH 60 (Cube Chorus) schematic needed
    Hello guys!
    I'm working with this amp and it isn't easy to me to find a trouble in the preamp section.
    I found in a thousand sites schems about Cube 60 (Orange), but this is a bit different...
    Thanks a lot!
    Best,
    M
    Originally posted by Panacha View Post
    Hello guys!
    Thanks a lot!
    Best,
    M
    So this is not it? https://www.manualslib.com/manual/13...-Cube-60d.html
    What is the amp doing or not doing?
    nosaj
      Hi nosaj, thanks!
      Nop...
      It's a old one...like the old orange, but with a basic chorus built in. From the 80's...all discrete, FETs 2SK117 and OP JRC4558...
      The amp have a variable hiss (like an open imput), works in his overdriven mode like a clean chanel, and with very pour volume at the max. in the normal input.
        Is it a Cube-60 or a CH-60? I get the impression those are two different models. And always include Roland in the search window.
          Hi nosaj, thanks!
          Nop...
          How about a pic of the circuit board and the amp? Even without a schematic we should be able to logically work it out.
          nosaj
            nosaj
            Think I found it. http://www.freeinfosociety.com/elect...ew.php?id=1327
            nosaj
            i just don't see the jrc 4558 though
              nosaj
              Very close...it is similar to that (same period I suppose), but with the chorus and discrete reverb driver...I had this schem, and the pre is similar but not equal.
              Thanks!
                Yes, asap I will upload the pics.
                  Hi Enzo,
                  the model name is Roland Cube CH-60, near 1983...
                  thanks!
                    Try this:
                    https://www.dropbox.com/s/pdtwlo2u8u...me%7D.pdf?dl=0
                    Direct uploading to this page does not work.
                      Originally posted by doctor View Post
                      Try this:
                      Actually when you reply look for the go advanced button, then scroll down to manage attachments which will give you the file upload manager.
                      I've only had a problem when files exceed the 4.5meg mark.
                      nosaj
                        It's a procedure, which I used all the time.
                        Today it does not work.
                        File's size is only 570KB.
                          Cube CH-60 {Scheme}.pdf
                          Here it is.
                          nosaj
                            Perhaps I have some problems with my local Internet.
                            But if you want, you can always find a way out.
                              Hi nosaj, thanks!
                              Nop...
                              Ok we have a schematic for you now. If effects are off. And you plug a guitar into Main In Do you hear the hiss? (albeit vol Will be low).
                              Now if you have a second amp with a Main In Take your roland with a guitar plugged into Normal(then Overdrive) >Pre OUT into Main in on second Amp Do you have the Hiss?
                              Thanks,
                              nosaj
