Ampeg 720-SN schematic needed
  • Ampeg 720-SN schematic needed
    Not sure if I'm missing something or maybe it has a name that I am not aware of, but I can't find the schematic for this amp on the web. Does it exist? It's quite a difficult amp to trace due to the layout.
    Well a quick search turned up the model name Jupiter II 720SN. Still no schematic info to be found but is this the same amp in this lisiting?
    https://reverb.com/item/4041215-ampe...om-flair-tolex
      That amp had two preamps I think.
      The power amp may be the same as the Dolphin.
      Aside: I couldn't resist.
      Jupiter II was the name of the Spacecraft in "Lost In Space".
      That show was a hoot.
      Danger! Danger! Will Robinson.
        That's the amp.
        There's no schematic in the back panel unfortunately.
        Pretty big bummer as it is a beautifully done amp, but I don't know if I have the time/patience to trace through it.
        The main issue appears to be in the preamp.
          No luck with any Ampeg schematic showing EF86.
