Looking for schematic for Fender Bantam AB763
  • Looking for schematic for Fender Bantam AB763
    V1 is a EF86
    https://scontent-iad3-1.xx.fbcdn.net...39&oe=5DBBAA3B
      I could be wrong, but I know of no such thing (with EF86). It's been modified as the tube chart says, and possibly the EF86 is part of the modification. I've never seen such a thing stock, but maybe someone else has.
        Funny how they throw around that 'AB763' moniker.
        EF86 tubes can be temperamental in a combo amp.
        They go micro phonic easily.
        Try to cut & paste the Vox 15 EF86 front end on to the 12AX7 schematic.
        Fender_bantam_bass_cfa7003.pdf
        AC 15.pdf
          I'm just curious. Are there really only 3 preamp tubes (or 2 and the PI) like the tube chart shows? If so, I'm not sure why anyone would mod for a single pentode instead of a dual triode. Seems silly. Is it modded for a single channel amp and the tubes are cascaded? Is there evidence an extra socket was added? So many questions. I wonder if the tube chart is even original. Maybe a pic would help?
            No way that tube chart is original.
            But would also like to say, an EF86 into an LTPI can sound quite good (& gnarly) if you bypass or dumb-down the tone stack & go for lots of gain... But yeah, I abandoned them because PITA tubes.
            Justin
              Originally posted by clintronics View Post
              V1 is a EF86
              If you do not represent too much effort, photo in detail preamp layout (part where the input tubes are)
              It's All Over Now
                For each case, upload a photo in detail from the preamp layout, so be sure of about what is being done.
                It's All Over Now
                  [ATTACH]54090[/ATTACH]
                  [ATTACH]54091[/ATTACH]
                  You nailed it, Thats exactly what the owner did. Sounds pretty good too.
