Hello again, after knowing that RS no longer stock the power amp module SDV1025-600 @£50. I've got in touch with EcoTec which makes both the SDV1025-600 PCB assembly and SDV1061-600 PCB with power transformer assembly. I was trying to get a quote for each SDV1061-600 and SDV1056-600 and find out whether anyone under their network chain has them(if direct purchase isn't allowed). Their reply was the SDV1061-600 was only made for Trace Elliot and the minimum order for it is 200 unit with lead time of 4 month. The SDV1056-600 is pending redesign until 2020. No dealers stocking any of the two.
Without a price to go with I may have to safe guess the SDV1061-600 could be at least @£750 a piece excluding shipping. I will try to check voltage rails if not fix the 1215 as advised by kind friends here but I'm also looking forward to raising the white flag in a week or two. I think I'll be happier ridding this amp out the door.lol
Thank you to fellow forumers for all the valueable info given here. Without them, I wouldn't know where to start or who to reach. Appreciate all the support. Keep up the good work.
Thank you
Thank you
