Pcb LAYOUT 5150
  • Pcb LAYOUT 5150
    Ive been searching for a long time online....i need a main pcb layout picture for a 5150 . Showing where the parts are located on the pcb .... NOT a schematic. Peavey scem files usually have this......cant find one
    There are a number of "5150" Peavey amps.
    Here is the combo & the head:
    5150.zip
      Instead of searching the web, if you just contact customer service at Peavey, they will send the entire file, not just the schematic.
        [ATTACH]54999[/ATTACH][ATTACH]54999[/ATTACH]
        Those seem to be empty......
        the amp is the original , early 5150 head , early 90s , before the 5150 II .
          "Those seem to be empty......"
          Not too sure what "Empty" means.
          Here is the unzipped file: 5150.pdf
            That opens for me and includes the layout.
              Here is the unzipped file: [ATTACH]55002[/ATTACH]
              ok--this one opened , has a pcb layout , but its for the combo amp.
                i found it----here :
                  That file will not work for us. Can you zip it?
                    try this
                      Yes that works, thanks.
