Torque Bass T2001EB
  • Torque Bass T2001EB
    Hi all, does anyone have anything on a Torque Bass T2001EB? I have a mouldy old girl that's blowing two of it's four internal fuses.
    Thank you.
    Until somebody finds a schematic:Torque amps in general were very simple , which is good in this case.+/- 40V raikls or so, 4 2N3055 or similar driven by a pair of TIP31-32 class transistors, etc.
    Post a couple close up pictures showing the power amp section, check power and driver transistor shorts, open emitter resistors, turn it on plugged into a bulb limiter, no speaker or any other load, start measuring voltages.
    For starters +/-V rails and speaker out.
    The general purpose drill.
      I'll take some pictures and measurements and start a new thread in the repair section
      Thanks!
