Hi anyone want to share schematic for Behringer di box Ultra DI100.
Behringer ultra DI100 schematic needed
https://music-electronics-forum.com/showthread.php?t=28596
https://music-electronics-forum.com/attachment.php?attachmentid=51538
1)
https://music-electronics-forum.com/showthread.php?t=49558&p=543909&viewfull=1#post543909
https://music-electronics-forum.com/showthread.php?t=50049
Hi Rajan
No need to spam the thread with the same request.
One Schematic Requests is sufficient for the same schematics.
And if you tried a little, you would find, if not schematics, then at least something similar.It's All Over Now
BEHRINGER Ultra -DI100:
something similar might not be helpful.
The BEHRINGER Ultra Di is maybe similar to the BSS AR133 and has a signal transformer.
The BEHRINGER DI-20 has a balanced input and no transformer.
Up to now I can't find a schematic of the Behringer Ultra -DI100
attached BSS AR133 which is different from Ultra DI100Attached Files
See Behringer DI DI20 (dual direct box), may be helpful or an idea.
https://music-electronics-forum.com/forum/schematic-requests/29353-behringer-di-di20-dual-direct-box-schematic
It's All Over Now
$ 46.00 for an active DI box.
And it will be economical to have it repaired?
Anyway: here are the particulars.
Features
- Professional, multi-functional active DI box for all studio and stage applications
- Behringer OT-1 transformer for ultra-linear frequency response
- Super-rugged metal encasing with sturdy oversized rubber corners for increased reliability
- Internal battery automatically shut off when phantom power is connected
- Ultra-low noise operational amplifier for outstanding audio quality
- Gold-plated XLR and 1/4" input/output jacks (XLR balanced)
- Direct connection of amplifier outputs with up to 3,000 Watts
- Switchable input attenuation allows input levels of up to +50 dBu
- Ground Lift switch isolates grounding circuit for hum elimination
- Manufactured under ISO9000 certified management system
COmpanies like behringer make a lot of products, and often the similar ones use the same circuits and parts inside.
Am I correct, does this DI box need phantom power to function?Education is what you're left with after you have forgotten what you have learned.
If it's your own time it's worth trying to fix. There can't be that much to it. What is the problem? How about you take the lid off and post a picture of the guts? We might be able to give you some ideas.Experience is something you get, just after you really needed it.
- Likes 2
