EV sb a760 subwoofer, sm or schematic
  • EV sb a760 subwoofer, sm or schematic
    Hi, I have to repair the power amp of the subwoofer model sb a760. Someone have the schematic or the service manual? The schemtic of some similar amp would be usefull. It's a class H power amp, with 2SC5200 and 2SA1943 output transistor.
    The faulty is in the base voltage: I have almost the negative rail.
    It seems like the Dynacord SUB 800A so I look into other Dynacord class H amplifier and I found that CL1600 is similar. I found a leaky medium power pnp transistor. After replace it the amp did work but after about 30 seconds the output transistor blows up. I hope that's due to the thermal runout, I don't attached the power device to the heatsink. From time to time also best ones do stupid things.
      Oops. Good luck. Hopefully not too much fresh damage.
        With new output transistor and the right setting of the idle current the amp works fine.
