Much appreciated if you can find this. Orange has several 100 models so this is very specific. All I’ve been able to find is the Rockerverb 50.
Need Orange Rockerverb 100 mkii
Hi Perkinsman,
I recently worked on an RV 100 (but it was a Mk I, not a Mk II) and if I remember correctly the only difference from the RV 50 schematic was that it had 4 EL34 in the power stage instead of the 6V6 tubes. Been a while since I've seen a Mk II, but I would suspect that it's also quite close to the 50 in the preamp (perhaps / probably identical) and differing in the power stage just like Mk I.
Is that not what you're seeing in the amp?
