New Month We are at $183.35 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
thought I would bump this up. I'm still looking. OR could I get some advice on what I should be looking for? I have correct voltage to the main board but even tracing it through the circuit I can't figure out why it's not making it to the wires leading to the preamp board. Where typically could this get lost? A bad component or a broken trace. I've inspected the whole thing for breaks. I do see one empty pad on the main board. That's why a schematic may help me figure out what was in there. Looks like someone has been in there trying to fix it.
while working on it, one of the leads from the clip on diode snapped at the case. I have to track one of those down before I can continue. The 1 ohm sand resistors started sizzling.... was my only indication. I couldn't even see the break till I moved the leads on the diode. Good thing I wasn't listening to music, never would have heard it in time to shut things down.
I disconnected the rails going to the preamp boards to see if the voltages changed on the main board....no changes.... is that step correct to help divide?
Gary:
The diode on the heatsink is in the bias string for the output transistors. The generic number is 1N3754, which has long been out of production. You can replace it with almost any silicon diode, but you will have to come up with some way to mount it down to the heatsink.
Check all the power amp transistors and the 1 ohm emitter resistors for any damage.
The only reason it's on the output transistor board is to dissipate heat in the clip? The metal casing of that diode has no relevance to ground?
Just the opposite. The diode senses the heat from the output transistors and reduces the bias to the output stage. The metal case is insulated from the diode itself, unlike the axial versions of diodes in that style case.
