Vox AC15CC1
  • Vox AC15CC1
    Has anyone ever come up with a schematic for this amp?
    I had one come in that the customer blew a 1 amp fuse and decided that a 3 amp fuse would be better.
    He roasted the unavailable power transformer.(50000000075)
    I am wondering if the AD15C1 transformer would work.(50000002130).
    Here is the schematic I have. The time I had to replace a PT, there were 2 physical sizes, depending on the year I think. They were not interchangeable.
      It needs to have the 25V winding for the LV supplies, yes?
      The only one I found was from mercury, so had to use that. (maybe because it was older version size). 2 x 2.5" centers was older, 2.5 x 3.125" was newer.
        Yep.
        25 v winding.
        2.5 x 3 1/16"
        I contacted Parts Is Parts and they are going to contact Korg/ Vox to see if they can tell me if the AC15C1 will work.
          Yep.
          25 v winding.
          2.5 x 3 1/16"
          I'm a bit confused. That measurement is for the C1 (530000002130).
          The part number you said was in there would be 2 x 2.5 (530000000075).
          Is there is room in there physically for the bigger one?
            Wrapping this up.
            The part that is available is the smaller transformer, (50000002130)
            The chassis cutout is larger so I had to come up with two steel straps to support the smaller transformer.
            The wiring colors are different but that was easy to figure out.
            Vox Power Transformer For AC15CC1, 530000000075 (partsisparts.net)
            Vox AC15C1 Power Transformer, 530000002130 | Parts Is Parts - Guitar Parts, Amplifier Parts, Korg Keyboard Parts
              About AC15C1 power supply
              https://app.box.com/s/n4rogzmzmt2i7dsubfno
              The problem can be only of a mechanical nature.
              It's All Over Now
                Here is a pic.
                  http://www.voxshowroom.com/uk/amp/ac15cc1_hood.html
                  http://www.voxshowroom.com/uk/amp/ac15c1_hood.html
                  Obviously the PT is not original.
                  It's All Over Now
                    "Obviously the PT is not original."
                    Not too sure what you are getting at.
                    The CC1 transformer failed and is not available.
                    So I installed a C1 transformer which happens to be smaller than the original CC1.
                      There's something horribly suspicious with that link. Security errors and endless redirects. Don't click on it.
                        Check the security settings on your pc.
                        The link clean, opens instantly (Malwarebytes + Eset installed)
                        Click image for larger version  Name:	untitled.JPG Views:	0 Size:	150.0 KB ID:	921390
                        It's All Over Now
                          This what I get
                          The error is "The certificate is only valid for contentcontrol.vodafone.co.uk."
                          If you chose to accept the risk you get into an redirect loop probably casued by my refusing cookies, which I'm pretty choosy about.
                            Click Advanced to update the security certificate expired.
                            It's All Over Now
                              Sorry, I didn't follow the previous posts, but answered the last post out of habit.
                              Is the C1 transformer supplied without the top protective (chrome) cover?
                              Sorry again for my comment.
                              It's All Over Now
