I am looking for a Garnet P-45B bass amp schematic. I think Garnet also relabeled amps with different names. The tube compliment is 12AU7 preamp, 12AX7 phase inverter, pair of 6V6 output tubes and solid state rectifier. Thanks!
Garnet P-45 bass amp
That's a Piper model number. Like you said, it's a stencil amp (built by Garnet).
Between the schematic dmeek posted and the one attached (less reverb and trem), you should be able to figure it out.Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Well I ended up sort of using both schematics. There is still no exact match that I can find.
Oddly enough I think this is my first cathode biased amp that I have ever worked on. (Of course most preamp tubes are cathode biased.) I will be very curious to see how it sound when I am done.
Links to Garnet schematic
https://www.electronica-pt.com/esquema/audio/amplificadores-audio/garnet/
https://schems.com/bmampscom/garnet/
https://www.thetubestore.com/garnet-schematics
https://elektrotanya.com/?q=showresult&what=garnet
http://www.schematics-free.com/modules/PDdownloads/viewcat.php?cid=63It's All Over Now
https://www.tdpri.com/threads/piper-garnet-p45b-bass-amp-rebuild.385445/
Single Channel - 20 Watts RMS
1-10"It's All Over Now
