Allen and heath ZED 18
  • Allen and heath ZED 18
    Hi everyone,
    I'm looking for schematic diagram of AG6747_3, or the value of R38 for the above PCB.
    The symptoms,us I checked previous topics, are well known common issues, us no signal throughout main outputs(only PFL works).
    So far I found U2 and R 38 damaged.
    Any help welcome and appreciated.
    Problem solved!!!
    Replaced U2 with TL072 SMD and R38 with 10ohm/0.5W.
    Currently all works.
    Thanks to everyone!!!
    Alternatively PCB AG6747_3 could be ordered in UK,from AUDIO-TECHNICA for £23.
    Part number 003#656
    Cheers
      hola yo tengo el mismo problema pero el que falla es el u6 con que se reemplaza saludos
        Originally posted by Vasilgv11 View Post
        Hi everyone,
        Do you have any idea where I can order that board AG6747_3? I looked on Audio Technica in UK and I can't find it. I need that board for my zed 18! Any help would be greatly appreciated. Thanks.
          Problem solved!!!
          Currently, all works.
          Alternatively, PCB AG6747_3 could be ordered in the UK,from AUDIO-TECHNICA for £23.
          Part number 003#656
          Cheers
          Dear Vasilgv11,
          Can you tell me, where you ordered, that PCB? Unfortunately, I am not able to find it on the Audio Technica site. If you can share with us the schematic diagram, that would be highly appreciated. In AG6747_3​ the U5 and two other resistors went off, but unfortunately, I cannot see it in the board as it is a bit burnt.
            zed10
            holiganbet betturkey
