MEF members...
Anyone have a schematic for the Randall Switchmaster 150, AKA "RSM-150"?
This is a two channel amp. Both channels are working but there is an issue with the channel switching. You cannot switch without the foot pedal.
About the foot pedal - the red light works (on the amp and on the footswitch). The red led is for the channel switching and in fact, when you stomp on the button you see the red light on the amp turn on and off. The green led is dead (on the footswitch). I need to replace that. I have some leds kicking around the house. The button (and green led) for the "both channels" is bad and that will be replaced. But I unsoldered the wires and used clips to make the connections. I cannot get the green light on the amp to turn on or off. I am assuming it does not matter if the led on the footswitch works. Unfortunately, there is no switch on the amp for this feature. I tested the male end of the connector to the wires in the switch - there is continuity. So I need to figure out why the "both channels" option is not engaging.
Thanks in advance!!
![Click image for larger version
Name: Randall RSM 150.jpg
Thanks in advance!!
