VOX Westminister schematic
  • VOX Westminister schematic
    I did some searching but can't seem to find this one...it is a bass combo from from the late 60's early 70's....there is a germanium transistor...AC187 which has the legs broken off from the body......it is obsolete and of course the recommended replacements are also obsolete.....any suggestions???
    Cheers
    Here is the Westminister V118 schematic:
      Thanks jazz....my biggest problem with this is trying to find a suitable replacement....I may have to use a silicon transistor which would mean changing out some resistor values....any suggestions kindly welcome...
        Worth a shot: https://www.ebay.com/itm/20264195403...43e977dc109ae9
          Sometimes if you contact those sellers they may have a more economical shipping option. That one is showing $55 to Canada.
            thanks guys...I doubt if the shipping will be any cheaper....I will check it out.....I think I need to register with ebay...
              The Westminister V118 does not use GE transistors.
              http://www.geofex.com/Article_Folders/Thomas%20Vox/Thomas%20Vox%20Replacements.pdf
              1)
              http://www.voxshowroom.com/us/amp/guardsman_power_amp_hood.html
              Thomas Vox 60 Watt RMS Power Supply/Power Amp Module
              2)
              Q6 = 2N2924 NPN predriver
              Q7 = 2N3054 NPN driver
              Q8/Q9 = 2N3055 NPN power
              3)
              http://www.voxshowroom.com/northcoast/referring/transistors.htm
              New Old Stock Replacement Transistors
              It's All Over Now
                I think the "+4.2V" on the base of Q8 is a typo. It should be 0.42V.
                Unless you are absolutely determined to go 100% authentic I would swap out the AC187 for a silicon type. You'll need to adjust the bias a little. Which one is it?
                • vintagekiki
                  vintagekiki commented
                  Editing a comment
                  It should be 0.42V.
                Digikey says there are 53 of these in stock. They should be a direct cross.
                https://www.digikey.com/en/products/...SABEgLfePD_BwE
                  Just checked the link....keep getting an error...will try to access digi key directly....Thanks for the tip...
                    I was thinking I would have to do that....I will do some more research and see if I can find a schematic.......
                    Cheers
                      Do you think about upload photo of your bass combo?
                      It's All Over Now
                        I will get a couple of pics and put them here....At present I am having some issues with my van...should have it taken care by lunch hour if everything goes well.....once I get over to the shop I will get some pics for you and post them this evening.....
                        Cheers
                          Late 60s - 70s Vox solid state bass combo is Vox Kensington Bass and Essex Bass.
                          Vox Sovereign and Westminster is bass amp head.
                          http://www.voxshowroom.com/us/amp/index.html
                          It's All Over Now
                            The Vox over to the shop is a one piece combo and labeled Westminister.....I'll get a couple of pics for you.....
