HB Wiring Help Sought,,,
  • HB Wiring Help Sought,,,
ID:	931072 Click image for larger version
ID:	931071 HERE'S the right schematic & I'd like for someone to sketch in where I could insert my Push/Pull/Volume pot, instead of the Volume pictured, so I can select the North or South coil when the on/on/on is in the middle (single) position? I would assume there has to be someone who could give me proper direction with this for my SH4 project..? Duncan can't help... I just sent off to GuitarElectronics.com, as it's their schematic..
    Thnx again!!
    Kenny
    SH4 https://imgur.com/gallery/8zLb0ZO
    https://www.fralinpickups.com/2017/0...ull-pots-mods/
      The push/pull pot will have three lugs just like the pot in the drawing, and the switch part of it will have six, assuming it is DPDT which most are. In other words it will be exactly like the layout you posted except that the volume pot and switch will be in one unit.
