Schematics for Hammond XK-2?
  • Schematics for Hammond XK-2?
    Hi,
    Got a Hammond xk-2 with no analog audio output for a song. Checked the mute circuit on the input / output board and it seems ok. Set of schems would make further investigation much easier! Thanks in advance!
    Do you know how different the XK-1 was from the 2? I attach here in case the parts you need are similar.
    What does "seems OK" mean? You get no line out? Do the headphones work?
    Hammond XK-1 sm.pdf
    And have you contacted Hammond/Suzuki to ask if they can provide the manual?
      Elektrotanya has XK-3.
        Thanks Enzo,
        Found the XK-1 sm already but thank you. Some similarities but definitely different starting with different analog output devices. Nothing out of headphones as well - from what I can tell looking at the layout, the mute is before all the output
        stages including the headphones.
        Emailed Hammond / Suzuki but got no response. Suppose I could try calling.
        Will take a look at the xk-3 and see if that is closer to the xk-2.....TY
          I always prefer calling over email. Calls usually get you a yes/no answer. Emails can easily get lost in the "don't bother" pile.
