Not easy.
In the OLD days, Ross was the "third" brand from Bud Ross, the first two being Kustom and Kasino, Ross amps being Asian made (Taiwan? Korea?).
I strongly suspect these are completely unrelated, simply some investor bought the Brand and sticks that label on generic OEM Asian amps.
I have repaired "Ross" amps where actual manufacturer was what we know as Samick (Korea) which is a LARGE OEM maker.
I seem to see 4 large Sanken power transistors in yours.
Suggest you post a couple pictures showing a general gut view, a bad channel closeup, show power and driver transistors, and maybe somebody recognizes it, or at least we can suggest some transistor replacements.
Very experienced Techs often can repair "without schematic" but that is hard to do by "remote control" through a Forum thread.
In any case , post those pictures.
Build a lamp bulb limiter so you don´t increase damage while testing.
The nice thing about repairing stereo power amps is that there are 2 channels. In many cases, you can use measurements from the working channel to diagnose the non working one. It makes repairing without a schematic and identifying burnt parts much easier.
As long as the power supply is working, but hopefully that could be done without a schematic (with some help, perhaps). From the gutshots I found of the MEGATECH 250 it looks like it was an actual transformer instead of SMPS for the PS, which is nice for diagnostics.
Hi,
Thanks for all the answers.
I will now measure all of the components individually. And if I still can't find anything, I'll throw Ross Systems in the garbage can and then open a beer
