Vox Pathfinder 10
http://i65.tinypic.com/290ub2f.jpg
Links to Vox schematics
This is a sticky topic.
Leave a comment:
Thomas Vox Berkeley II V1082 ; Vox Cambridge Reverb V1032
http://music-electronics-forum.com/attachments/40764d1474599227-vox-berkley-ii-v1082-1032.pdf
Thanks MWaldorf
Leave a comment:
Thomas Vox V1032 Cambridge Reverb
http://music-electronics-forum.com/attachments/40730d1474330295-vox_cambridge_v1032_full.png
Thanks MWaldorf
Leave a comment:
Not too sure if this could be termed a "Factory' defect.
C16 & C17 are power supply bypass caps.
Placing Electrolytic caps in those two positions is fine.
As long as the polarity is observed.
While a ceramic cap would be less likely to explode, they do have failure mechanisms of there own.
You very well may be seeing a bad batch of e-caps.
(From the infamous late 90's 'bad cap' fiasco.)
Leave a comment:
Vox VT30 factory defect Valvetronix with incorrect capacitors
AD15_30VT.pdf
I have fixed several of the VT-30 models. The issue with all of them has been that an electrolytic capacitor with the wrong value (.47 uF) is used in place of a 0.1uF Ceramic capacitor in either c17 or c16 right side of the power amp chip just in front of the green resistor. Some of the amps I've fixed, this capacitor literally exploded spraying paper pulp and melted metal around the inside of the amp. When that happens, the output is very low and distored, because only one side of the output is generating. In other amps, the problem is hissing and squealing, but the capacitor appears intact. They always test bad after removal. I replace them with the CORRECT value CERAMIC capacitor and the problem is much improved.
I have been unable to find any other reference to this defect.
Thanks for allowing me to post it here.
-Dave
Leave a comment:
Vox JS-DS Satchurator schematics
http://www.scribd.com/doc/283272829/Vox-Satchurator
Schematics Vox Satchurator distortion pedal of Joe Satriani
Leave a comment:
Leave a comment:
Vox AC30CC2(X), AC30CC1 schematics
http://music-electronics-forum.com/attachments/26385d1384908846-ac30c2.pdf
http://bmamps.com/Schematics/vox/Vox_AC30CC2_AC30CC2X%20(2005)%20SM.pdf
http://web.archive.org/web/20060518222724/http://www.mzm.us/AC30CC_Schematics.pdf
AC30 Custom Classic schematics
Amplifier schematics are identical, different is only in the number and type of the connected speakers (see page 5 owner's manual) to the output transformer (see AC30 power amp on the schematics)
In both cases, the output select switch (SW6) is in position 16 ohm
AC30CC1: 1x12" combo with a custom voiced VOX NeoDog speaker
AC30CC2: 2x12" combo with a pair of custom designed GSH12-30 speakers
AC30CC2X: 2x12" combo with the world revered Celestion “Blue” 15 watt AlNiCo speakers
http://www.voxamps.com/uploads/SupportPage_Downloads/AC30CC_EFGS2.pdf
Vox AC30 Custom Classic owner's manual
Leave a comment:
thanks for this encyclopedic compilation / an amazing resource !
Q: is the AC30CC1 circuitry identical to an AC30CC2 (with the exception of the 1 spkr vs 2...)
Leave a comment:
US Bass Vox Ampifiers 1965 - 1971
Kensington Bass V124 - 22 watt RMS
Kensington Bass V1241 - 22 watt RMS = Kensington Bass V124 + G tuner
http://www.voxshowroom.com/us/amp/kensington.html
Essex V4, V104, V1041 - 35 watt RMS
Essex V1042 - 35 watt RMS = Essex V1041 + foot switch "Tone X "
Essex V1043 - 50 watts RMS = Essex V1042 preamp + G tuner + 50 watts RMS Power Amp Module
http://www.voxshowroom.com/us/amp/essex_hood.html
http://www.voxshowroom.com/us/amp/essex.html
Westminster V118 - 60 watts RMS
http://www.voxshowroom.com/us/amp/v118_preamp_hood.html
http://www.voxshowroom.com/us/amp/west.html
Westminster V1181 - 60 watts RMS = Westminster V118 + G tuner
http://www.voxshowroom.com/us/amp/v1181_preamp_hood.html
Westminster V1182 - 120 watts RMS = Westminster V1181 preamp with 120 watts RMS Power Amp Module
http://www.voxshowroom.com/us/amp/v1182_preamp_hood.html
Sovereign Bass V117 - 60 watts RMS = Westminster V1181 with Four Oxford 12T6 12 Vox Gold Bulldog 12"
http://www.voxshowroom.com/us/amp/v117_preamp_hood.html
http://www.voxshowroom.com/us/amp/sovereign.html
60 Watt RMS Power Amp Module
http://www.voxshowroom.com/us/amp/guardsman_power_amp_hood.html
120 Watt RMS Power Amp Module
http://www.voxshowroom.com/us/amp/beatle_power_amp_hood.html
Schematics Vox Kensington V1242
http://music-electronics-forum.com/t20442/
Schematics Vox Westminster V118
http://music-electronics-forum.com/t34683/
77411Last edited by vintagekiki; 11-27-2015, 08:31 PM.
Leave a comment:
I am not familiar with that amp but found this:
http://www.voxshowroom.com/northcoas...g/essexsch.htm
Alf
Leave a comment:
Vox Pathfinder V1 (V101) & Vox UL 705 schematic
Basically amplifiers Vox Pathfinder V1 (V101) and Vox UL 705 schematic are very similar amplifiers.
Unfortunately I was not able to see them, so the schematics is drawn on the basis of various photos from the Internet photos of type Look "Under the Hood"
Based on my 30 years of engineering experience, I tried at all the photos to find a common point, and as a result of the schematics that is located in front of you
Allow minor glitches during the conversion layout amplifier in the schematics.
Some of the links used when creating schematics
http://www.voxshowroom.com/us/amp/path.html
http://www.voxshowroom.com/uk/amp/705.html
http://vox.opensure.net/images/705/closeups/
http://vintageamps.com/plexiboard/viewtopic.php?f=2&t=92166
https://reverb.com/item/551551-vox-pathfinder-v1-1966-black
http://web.archive.org/web/20121218181106/http://www.jmiamplification.com/combos/jmi-4
Attachments "Under the Hood"
http://vox.opensure.net/images/705/closeups/705_25.jpg
Vox UL 705
http://web.archive.org/web/20150705123639/http://www.jmiamplification.com/images/product/2/509120bac4701.jpg
Jennings Musical Industries JMI 4; Vox Pathfinder V1 (V101)
Do not mind the possible grammatical irregularities, translation is the machine https://translate.google.com/
vkLast edited by vintagekiki; 11-26-2015, 07:09 PM.
Leave a comment:
Leave a comment:
