I need a Line 6 Spider III 75Watts Guitar Amp Diagram
  • I need a Line 6 Spider III 75Watts Guitar Amp Diagram
    Hello friends good evening, if someone could provide me the diagram of the Line 6 Spider III 75 Watts Guitar Amplifier, very grateful in advance, greetings.
    Maybe this?
    https://music-electronics-forum.com/...etch?id=836095
      Thanks The dude, but the ic Amp of my spider iii is the tda7293 and I would like to know the voltages of the mute (pin 9 and 10) and of pin 6 and 12, because I tell you that WITHOUT connecting the plug in input the TDA7293 does not heat up and 15v appears on pin 6 and goes down to 9v, 8v and so on (pin 12 = 0v), on the other hand, on pin 9 and 10 there is 0v, now if I CONNECT the plug, the voltage of pin 6 = 16v and pin 12 = 0.5v, and on pin 9 and 10 you have 8.1v and the integrated heats up with volume to zero and with the speaker connected, I turn up the volume and it works ok (I understand that it is not recommended to turn on the line6 amps without the speakers). The concern is that the amplifier works but the integrated heats up or if it is normal, it does not heat like an iron either but it does heat up something and you do not want to continue testing until you know the voltages of this integrated.
      The + Vcc and -Vcc is 42V, if you can help me or know if it's okay, those voltages would be great, thanks
        https://docdro.id/BXppUGc
          Thank you very much my friend Suggested and I doubt you for helping, this last diagram helped me, greetings friends
