MARKBASS Nano Mark 300 - schematics request
  • MARKBASS Nano Mark 300 - schematics request
    Hi eveybody
    Could you have MARKBASS Nano Mark 300 schematics or service manual ?
    It's impossible to find it on the web
    thx in advance
    Chris
    Chrissss, I don't have it, and know that Markbass controls their schematics somewhat, but I've worked on a couple and found that they reuse quite of bit of circuit design across models. The circuit designators will be different, but often the mechanisms are the same or similar. On the ones I've worked on the failures tended to be very small things, like a cap that leaked DC or a op amp that just died with no real reason why it would happen.
      But this is a Class D power amp,
      All versions of Little Mark are equipped with a classic Class AB power amp
        Well, do you have the right schematic to share? Or other suggestions?
          What is wrong with the amp?
          If it is an output issue, find the class d chip and look up the datasheet.
          Most manufacturers follow the sheet to a T.
            it is a strange behavior
            volume is too low with distortion, sometimes after turn off and on it's ok
            it happens accidentally
            mostly amp works properly but you'll never know when it might happen
            it's a little annoying
              the problem is that I dont have right schemattics
              here are all schematics I found:
              https://elektrotanya.com/showresult?...a=All&kat2=All
              unfortunately all of them are class AB
                one important thing
                the problem occurs only whent I turn on amp,
                when amp starts normally is ok, it can work for hours with no problem
                  Does your bass cab have a piezo tweeter? Class D amps sometimes have stability issues when driving capacitive loads, which is what a piezo will look like IIRC.
                    Nano Mark 300 is loaded with Markbass New York 122 (2x12", 1" voice coil tweeter, Impedance: 4 Ohms)
                    http://www.markbass.it/product-detail/new-york-122/
