Need schematic for Electro Voice ZXA1
  • Need schematic for Electro Voice ZXA1
    As the title says, looking for a schematic for the EV ZXA1. It's a little powered speaker.
    I tried EV and was told they only release schematics to authorized service centers.
    Oh and EV used to be so friendly when they were in Buchanan Mich.
      Yep. Things have changed radically since they were bought by Bosch.
      I checked as much as I can without paper. Switching supply seems to be working- +&-15 at op amps, +&-66 output rails there, no shorted outputs, signal all the way to master volume control, etc. The amp appears muted- not even hiss from speaker. I need to find out why.
        I assume you have tested the speaker including is wiring all the way to the amp circuit?
          Yes sir. Drivers Tested (horn driver and speaker both good) and wiring. Scope shows no output to the speakers from the amp.
            We got some bord photos? What sort of power amp. Is it perhaps biamped even? power IC or discrete transistors?
              I've already reassembled hoping for schematics. I've got too many repairs in the shop to spend more time on this one at the moment. I'll upload photos when I get back into it. FWIW: I believe it's biamped and has IC driven FET outputs.
