CS-400 84B Schematic
    Enzo,
    Yes, I can open the cross reference. Can you open the reposted PDF from this your post?
    Thanks,
    Albert
      I can open all the links. I am using the plain old microsoft explorer or whatever it is called. And I just opened them in Chrome.
        The schematic in post # 5 is 'invalid file specified'. The 'resave' schematic in post # 10 is a corrupt file the adobe reader will not open.
        Attached is the file from elektrotanya.
          Geez, what is wrong with my files?
            The 'resaved' is corrupt. If it is opening on your computer, it must be a local or cached copy. The original one in post # 5 was the typical 'invalid file specified' which may also be opening ok for you on your own computer.
              My original is from the pre-crash days, so it won't open on newer reads, that was what the resave was, a slightly altered copy. I have uploaded it in the past successfully.
                The 'resave' file downloads properly, but when you try to open it in adobe reader, it gives this error message:
                  I believe you, I just don't know what it means.
                    I had trouble opening it on a Windows 7, 32-bit computer. It works properly for me with Chrome on a Windows 10 computer.
                      Bottom line is that you now have a readable CS400C schematic set?
                        Thanks for all your help and advice on other posts too! I got the amp working. I had three bad output transistors and an open 0.33 ohm, 10W resistor. I replaced all 6 output transistors on the channel since I've read they should be matched and I was afraid the remaining good ones could've been stressed and it was really easy. It didn't really take me this much time to get this doen; I had some other things I had to do.
                        Coming back here to thank you, I realize I didn't reply to your last post - sorry.
