Need a schematic for garnet Rebel w/tremelo and stinger. Thanks.
Garnet Rebel w/tremelo and stinger
Try here
https://www.thetubestore.com/garnet-schematics
Edit:
Or try this one
https://www.guitarscanada.com/thread...tremolo.70337/Last edited by Delta362; 04-05-2022, 06:28 PM.
There should be an actual model number, with a letter followed by 90 or 100. Does it use 6L6, or 6V6 power tubes?
The 'delux' schematic shows trem and stinger, with 6L6 power tubes.
The others show 6V6, one is an amp with trem., one with stinger. If the amp has 6V6, you will have to use a combination of those 2 schematics.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThere should be an actual model number, with a letter followed by 90 or 100. Does it use 6L6, or 6V6 power tubes?
The others show 6V6, one is an amp with trem., one with stinger. If the amp has 6V6, you will have to use a combination of those 2 schematics.3 Photos
See them occasionally, not the Rebels so much.
The pg.1 of lb100ft (deluxe) schematic should match the preamp, the power supply and power amp will be more like the L90 schematic.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
