Crate GT200 DSP Schematic?
  • Crate GT200 DSP Schematic?
    Anyone? This is the one with 4 preamp tubes and chorus that is separate from the DSP effects.
    TIA
    All i can find is this one....
      That's better than I had, so thanks! Amp actually sounds good except for the SS lead channel, which sounds like it has a wet blanket over it. I find these amps pretty interesting in general with the tube driver stage going into FET output stage.
      Looks like there is a network after the clipping diodes that rolls off the bulk of the highs (probably more like mids) but then a treble bleeder for the higher frequencies, wonder if there is something going on there.
        This schematic does work for the DSP version, except they didn't populate some of the components around the reverb circuit and instead send the signal over to the DSP module.
