Peavey Solo Series Bandit 112 (1992-1995) Teal Stripe Version
  • Peavey Solo Series Bandit 112 (1992-1995) Teal Stripe Version
    MEF Members....
    I am having difficulty in finding the schematic for the Peavey Solo Series Bandit 112 (1992-1995) Teal Stripe amp. The manual pdf is attached.
    I have the schematic for the Solo Series 112 Gen 1 amp; made in 1989 to around 1992.
    Does anyone have this particular schematic on hand?
    Bandit_112_Teal_Manual.pdf
    Close... but not quite. The Teal version has two buttons between the SuperSat and Post Buttons.
    I believe this amp was made between '92 and '95.
    Click image for larger version  Name:	Front 1.jpg Views:	0 Size:	131.2 KB ID:	970312
      Is there a PCB# or name etched on the foil side?
        I do not have the amp in my possession. It belongs to a friend. So it may be a week or two before I get it. I'm just prepping for the day when it arrives. I will keep looking and will post it here if I find the right one. Thanks !!
          Ok.... I do believe this is the one.
          The schematic looks almost identical to #3 posted by Dmeek. But if you look at the layout diagrams, they are different.
          The schematic I am posting here has a 1989 date - hmmmm. But the board layout looks very much like the Teal Stripe. The big difference between the Bandit 112 Gen 1 and the Teal is that the Teal has two buttons between the SuperSat and Post knobs.
          So unless I find something else with a later date, this must be the one.
          Bandit_112_Teal_Stripe_Schematic.pdf
