Evh 5150-3 help !
  • Evh 5150-3 help !
    Ok guys...im lost here. I cant find a scem that jives with what im seeing inside this amp.
    its a early version EVH 5150-3 , 50w combo , 6L6 , 1x12 MADE IN MEXICO .
    It looks like someone mis-wired the PT to the pcb. The 2 scems i found = 1 is blurry as hell , the other doesnt match the spade connections on main pcb----as far as P16 , P17 , etc.... It looks like someone screwed up the wires plugging them in . Ive got 120v on my ac heater wires where i need 6vac . Its 100% wiring because this is a brand new transformer.......i thought the old one was shorted (120v on the 6v tap)
    I have several versions. This one says Mexico. I have more if it's not the right one.
    evh_5150iii_50w_mexico_schematics.pdf
      I have this one from Fender who took over the EVH 5150-III, which I got from Enzo, I believe.
      Fender EVH 5150-III head.pdf
        Thank you------amp is up and running !!!
