Crate G-20C schematic?
  • Crate G-20C schematic?
    Amp is working, but wondering if a small mod in the lead channel bit of the preamp might make this amp usable. Don't know if any of other Crate amps that used the SCG lead circuit would be the same or similar.
    TIA
    Maybe G40C close.
      Originally posted by fewa View Post
      Maybe G40C close.
      Thanks. I think this schematic for the G20XL is closer for the SCG part of the circuit, although my G20C only has an on/off switch for the SHAPE instead of a pot.
      G-20XL Schematic.pdf
      I did some experimenting with putting an EQ pedal in front of the Crate and cutting the low frequencies really helped the gain channel. Without the cut it is way too woofy and wooly. With the lows cut it reminded me a bit of a GK 250ML.
        Here it is...
Name:	Crate GC20 schematic page 1.jpg
Name:	Crate GC20 schematic page 2.jpg
          Awesome, thanks!
          Wondering if lowering C7 (2.2uF) would tighten up the lead channel a bit. Don't know why they would put a capacitor bigger than any others in the signal chain there.
