Crate GX600 head Schematic
  • Crate GX600 head Schematic
    I'm looking for the Crate GX600 schematic. What I found has the correct power amp, but the preamp circuit does not match. This particular amp has two inputs (0dB and -6dB), bright switch and channel switch. There is no gain switch. The GX preamp schematic associated with the schematic I found doesn't line up.
    The GX130 might be similar
    GX130C sch.pdf
      https://elektrotanya.com/crate_gx-60...wnload.html#dl
        Try this one
        GX-600, 1600 Schematic.pdf
          Originally posted by dmeek View Post
          Try this one
          [ATTACH]n982486[/ATTACH]
          That's the one! Thank you!
          holiganbet betturkey
