KRANK scem
  • KRANK scem
    Apparently these dont exist.....none.
    I need a scem for a Krank Revolution 1 . Its a 2005 . They made a lot of these amps ....... but after 83.2 hours of searching on the world wide web = nothing.
    Anyone ???
    Just a reverse engineered schematic
Name:	Krank Rev1 Pre.gif
Name:	Krank Rev1 PA.gif
      THANKS!! weird how they label pre amp tubes backwards
        What do you expect from a Krank amp?
        (krank is German and means sick)
          Its definitely no Bogner or Engl inside.....
            That schematic is not from the factory, so it may be the author that designated the preamp tubes V4 > V1, rather than the conventional designations (V1 at input).
              I've got my buddies 2006 Rev 1 and the board labels the first tube in the signal path as V4 and the PI as V1. I wouldn't be surprised if it was an oversight and the pcb's were already produced so they just used them.
