Eden Wt-300 schematic
  • Eden Wt-300 schematic
    No heater voltage between pins 4, 5 to 9. I get heater voltage only between 5 and 9
    Is that with or without a tube installed?
    It is a series connection.
      Lower area of pg.2 of schem. Like Jazz said, they are series filaments, so I don't see how there would be voltage between 5 and 9 without also being between 4 and 5.
      You may have to dig in harder with your meter probe.
        Without, I see it now. I substituted another 12ax7 which also turned out to be bad. Brand new tube and it works fine now. Chased my tail for a little bit there, thank you for your help!
