music man circuit breaker
  • music man circuit breaker
    mm amp has small glass circuit breaker clicks on and off. I think the rectifier is bad any ideas?
    breaker
    HMMMMM? This sounds like one over at the MM boards! Anyway, those thing are junk. Wire around it and try it. That amp has a SS rectifier so chances are it's OK. If the tubes are junk, that could be tripping it too but I'm betting on junk neon lamp.
    PS-If you're concerned abou smoking something, wire yourself up a test lamp with a 110v ligt bulb in line with the + side of the power chord. This will serve as your second fuse. If the lamp glows a dark orange with a 60 watt bulb or so in it, it's ok. If it's bright, like a full out light bulb, it's pulling too much current but the bulb will stop the fuse from blowing.
