Originally posted by RedHouse
View Post
Different specs for dimmer switch speed controls ?
I'm not sure if this is helpful to anyone at all but after much experimentation I've found that these 450 watt light dimmer's work really well on vertically every AC motor I've tried and it provides great speed control although the brush-less motors tent to hum a little at low speed.
kind regards to all
WaltI know the voices in my head aren't real..... but man, sometimes their ideas are just brilliant.
Originally posted by walcen View PostI'm not sure if this is helpful to anyone at all but after much experimentation I've found that these 450 watt light dimmer's work really well on vertically every AC motor I've tried and it provides great speed control although the brush-less motors tent to hum a little at low speed.
kind regards to all
Walt
Originally posted by Joe Gwinn View PostSure. here:
How does that help low speed?, and what effect does DC have on an AC motor at low speeds?
Also your PDF maker seemed to cut off some of your verbiage, this is how it displays on my screen (Acrobat-9):
Originally posted by Joe Gwinn View PostBrushless DC motors contain an electronic controller plus a form of induction motor, so a ceiling fan controller probably won't work at all, and may damage something.
There are lamp dimmers that work well with universal-wound motors. Lutron is a good brand.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by RedHouse View PostI think I get the drift Joe, thanks.
How does that help low speed?, ...
A universal wound DC motor has field winding and rotor winding in series, so the direction of rotation does not change if the polarity of the supply is reversed. To reverse, one must rewire the motor.
Originally posted by David Schwab View PostJoe, would a lamp dimmer work with a brushless DC motor? I'd like to fix my Schatten winder so I can sell it. I could try replacing the rectifier on the speed control board, but it seems like it is a faulty design since they seem to be failing on people.
But to answer your question, I would be surprised if a brushless DC motor was happy being driven by any kind of lamp dimmer.
Standard 110 volt lamp dimmers put out far too much voltage for such a motor. One can get lamp dimmers intended to drive low-voltage (12 volts being common) halogen lamps through a transformer. Such a dimmer with transformer and rectifier bridge could work, but this is getting expensive.
I would replace the blown rectifier with an electrically larger component first.
Actually, Schatten may offer repair and/or parts, given that it appears to be a design problem.
but... try to change rectifier with a bigger one....
post a photo of the control board...........my gaussmeter project..... ........
.......first pickup with my cnc winder........
.... NEW cnc pickup winder user manual.....
Originally posted by Joe Gwinn View PostIs it really a brushless DC motor? They are expensive. Small DC motors can have brushes inside that are not externally visible.
Work with dimmers?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostIt's a small DC motor. I guess it probably has brushes. It has a small controller board on one end. It certainly wasn't expensive.
Work with dimmers?
Actually, doesn't the Schatten run off a wall wart? If so, the voltage will be low, and direct connection to a 110 volt dimmer will cause sparks and fire.
I've never seen the Schatten, so I'd like to second Elpro's request for photos.
Originally posted by RedHouse View PostAw darn! most of my motors are horizontal...
You see? this is what Virtually happens when your eye sight begins to Virtually fail you and spell check Virtually gets it wrong. Sorry for the typo.
Back on subject, for DC motors between 12 and 35 Volts I have found that a simple pulse width modulator works really well and provides good motor speed control. they are easy to build from a kit or purchase from E_Bay.
Here are a couple I made, the cheep one is good for 12-15 volts DC.
The other is good for 12-35 volts DC
DC Motor Controller Kit (K3070) | Dick Smith Online Store
Bi-Directional DC Motor Speed Controller Kit
I hope this is helpful.
regards
Originally posted by Joe Gwinn View PostActually, doesn't the Schatten run off a wall wart? If so, the voltage will be low, and direct connection to a 110 volt dimmer will cause sparks and fire.
I've never seen the Schatten, so I'd like to second Elpro's request for photos.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
The LM 317 is an adjustable voltage regulator. You can get from 1.5 to 35V at up to 1A. So it doesn't look like a PWM based speed control but a variable voltage controller. I can't really imagine why he did it that way. Looking at his PCB it doesn't seem like electronics is his forté.
There should be a good sized filtering cap(s) somewhere in there which I'm not seeing..
The + and - stamped into the back of the motor case tells me that's a DC motor, probably 12V.
How many volts is the wall wart putting out?
Mabuchi only makes DC motors, they are the worlds #1 producer according to wikipedia.
I looked through their online catalogue and couldn't find one that looked like this.
If you know the dia and the voltage, you can look it up here:
http://www.mabuchi-motor.co.jp/en_US...ct/p_0303.htmlLast edited by David King; 03-01-2010, 06:51 AM.
Originally posted by David King View PostThe LM 317 is an adjustable voltage regulator. You can get from 1.5 to 35V at up to 1A. So it doesn't look like a PWM based speed control but a variable voltage controller. I can't really imagine why he did it that way. Looking at his PCB it doesn't seem like electronics is his forté.
Search by Required Motor Performance | MABUCHI MOTORIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
