Results 1 to 3 of 3
Thread: Power amp design from scratch
    New Member
    Jan 2010
    3
    0
    Hi all
    I'm trying to design a power amp section for an amp I am building and am struggling to find sources on the topic that explain why every value is what it is. I am building my amp for a project at uni and need to justify the value of every component 'in the box'. I am using EL34 valves in a P-P setup. I have managed to get the preamp and the power supply all done, but am stumbling on the power amp section, so any help at all will be a real boost!!
    I've been using Merlin's book for the preamp, and his website for the power supply, but the power amp section feels a bit 'glossed over' and just can't seem to obtain the information I need from it.
    Sep 2009
    104
    11
    Here you go: Technical books online
    There are a bunch of the classic books here with everything you need to know to design an amplifier. Good luck!
    Dec 2008
    Wernersville, PA
    13,074
    Received: 610/3
    Given: 314/0
    28
    Output Tube datasheet
    You really should learn how to read & apply the tubes parameters from the datasheet.
    Search "Load Line".
    Franks Electron datasheets on just about every tube ever made.
    Frank's Electron tube Pages
  1. Power supply for from-scratch preamp
    By chipaudette in forum Theory & Design
    Last Post: 11-30-2007, 12:10 PM
  2. How to calculate theoretical power at the design stage
    By macwanj in forum Theory & Design
    Last Post: 11-14-2007, 05:22 AM
  3. How to design power supply for tubes?
    By Realeigo in forum Theory & Design
    Last Post: 10-25-2007, 12:58 AM
  4. Power amp design
    By chunkitup in forum Theory & Design
    Last Post: 07-07-2007, 03:27 AM
  5. EL84 power amp design
    By zikaj in forum Theory & Design
    Last Post: 05-18-2007, 02:07 PM
Tags for this Thread
