Results 1 to 2 of 2
Thread: Fishman Loudbox Pro - intermittent output
    Junior Member
    Jun 2011
    Oxford, UK
    14
    0
    Hi - I got a Fishman Loudbox Pro intermittently cutting out, in the workshop and thought I'd give a heads-up on what the problem was..
    Firstly I have to say this amp is over-engineered to hell and is a real bitch to open up, dozens of screws and lots of different sizes., you have to remember to remove the long handle screws, which go through some aluminium tubes and then into the chassis. The heatsink is huge and makes access to the flip side of the pcb very difficult.
    To cut a very long story short I thought I'd attach a clip from the crossover board, the section with the power-up MUTE circuit
    spot the deliberate mistake? That C85 is an SMD cap, about the size of a match head and it's had 28V across it once (or maybe twice) too often!
    Changed it for a a 10uF 50V and it's now solid as a rock.
    Dec 2008
    Wernersville, PA
    13,005
    Received: 569/3
    Given: 299/0
    28
    Nice fix
  1. AOR intermittent low output
    By Zozobra in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-07-2012, 06:21 PM
  2. How do I open a Fishman Loudbox?
    By Albert Kreuzer in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-18-2011, 12:41 PM
  3. Fender Stage 100 DSp Intermittent Output
    By hatcherd in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2009, 05:35 AM
  4. Fishman Pickup?
    By ArnC. in forum Music Electronics
    Last Post: 03-31-2008, 06:56 PM
  5. Fishman Lunchbox whoops Loudbox Hexfets
    By oc disorder in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-03-2007, 10:25 AM
Tags for this Thread
