Output on little transistor organ, loud hum
  • Output on little transistor organ, loud hum
    Hi there,
    This is my first post here so I hope this is the right place to ask.
    I bought an inexpensive analog transistor based organ. It's a Gracia (Armon) Charlie 37. It was in bad shape; noisy pots, lots of dust, paint + sharpie markings + stickers on the keys. I totally cleaned it up and it looks like this now:
    100_1271_zpse8e8bffc.jpg Photo by AJDbass | Photobucket
    It has a build in speaker. I wanted an line out to amplify the organ so I could use it for rehearsels with the band. There was a jack input for a pedal wich was missing, so I pulled out this jack and replaced it for a line out-jack. I found the pcb which contains the power supply and the power amp. I bypassed the white wire which goes to the input of the power amp. The white wire now goes from the output jack to the power amp. If a cable is inserted the signal to the input of the amp is broken.
    100_1277_zpsf708911c.jpg Photo by AJDbass | Photobucket
    The level of the line out is perfect for a guitar amp and I can control it with te volume control on the organ. The problem is that when there's a cable in the output and there is no signal to the poweramp of the organ, the internal speaker gives a loud hum.
    I don't really know how to eliminate this hum. I don't have a schematic. I was hoping someone could give me some tips... I am kind of stuck. Thanks.
    You need to replace your jack with a type that has another switch contact which will ground the input of the power amp when you use the line out.
      Something like this: Fender Jack Switchcraft 13A Transfer 0041701000
        I don't think that that one would work.
        I looked up the Switchcraft numbers. A #54A might do it.
        Or use a 3 conductor jack with closed circuit contacts. Wire the tip to the signal output, the tip NC contact to the power amp input and also to the ring contact. When a mono plug is inserted the ring contact (power amp in) will be grounded through the sleeve of the mono plug.
          Thanks everyone! Grounding the input did the trick, works perfectly! No hum and noise from the internal speaker and no hum on the line out.
          I connected the input from the amp with the 'ring' contact from the stereo jack I already used, like 52 bill suggested.
          Can't wait to use it on the next rehearsel!
