Results 1 to 8 of 8
Thread: Debugging a Line6 DL4. Help needed!
    New Member
    Jan 2017
    3
    Exclamation Debugging a Line6 DL4. Help needed!
    Hi!
    I hope you can help me fix a dead Line6 DL4 that won't power up and it's giving me headaches.
    First, the schematic:
    https://www.docdroid.net/JYZyjup/tmp...48780.pdf.html
    I disassembled it and made a visual inspection first. Nothing wrong. I did check voltages, all correct till U14. Touched U14 (MAX887) and was very Hot and giving wrong voltages. Pin 7 was giving 0V instead of 3.3v.
    A bunch of components are fed by the 3.3v line, with U2 (DSP56364) being one of them.
    After a lot of tracking, I found out that if I cut the 3.3v trace near pin31 of DSP56364, the voltage of the whole line is restored and MAX887 operates correctly.
    I thought that the DSP56364 was shorted, so I replaced it with a new one (super expensive, BTW) and didn't made an improvement. MAX887 is still very Hot and 3.3v drops to zero as soon as the pin31 of the DSP56364 is connected.
    Here's the DSP56364 Datasheet :
    http://www.nxp.com/files/dsp/doc/dat...t/DSP56364.pdf
    Any ideas on this? What could cause the short?
    Many thanks guys
    Old Timer
    Dec 2007
    Poland
    1,578
    Received: 12/0
    Given: 3/0
    Aren't the memory ICs supplied with the same 3V3 voltage? In such a case I would check blocking capacitors like C26, C33 and others.
    The link to the schematic does not work (at least for me).
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,806
    Received: 723/4
    So U14 is hot, either it is bad or its output is loaded. You isolated U2, but was it getting hot? You showed yourself it wasn't the problem.
    Are any of the other 3v chips getting hot? And those little bypass caps, any of those get hot? Try just lifting those caps off anyway, they are more likely than the ICs to fail.
    Dec 2008
    Wernersville, PA
    12,389
    Received: 138/2
    Given: 43/0
    Quote Originally Posted by MarkusBass View Post
    Here is the downloaded file.
    Attached Files Attached Files
    New Member
    Jan 2017
    3
    Many thanks guys!!!
    Never thought of that! U2 was never getting Hot, but when I lifted it, U14 came back to life and 3v3 rail was showing voltage back, so I suspected U2 was the problem. But it can be U14 not dealing with load, that's true! No other component got hot. Bypass caps seemed fine. I have ordered one MAX887, will replace it and see what happens.
    You helped me a lot. Thanks!
    New Member
    Jan 2017
    3
    Solved: replaced MAX887, the pedal came back to life. Many thanks to all for the help!
    Old Timer
    Jun 2006
    Norristown state hospital
    1,915
    Received: 31/0
    Got one of these that has all the proper power supplies, nothing getting hot but it won't engage the relay and doesn't do anything.
    The 3.6v zener was shorted, but I'm using DC voltage for now until I order the diode.
    I pulled it for now.
    Clock oscillator is working.
    I will check the switch pulses to the dsp.
    Anything else to look for?
    Old Timer
    Jun 2006
    1,915
    Received: 31/0
    Actually all clocks are correct except nothing at DAC test pad which is a clock coming from U7 I believe....
  1. Line6 DL4 power supply repair
    By beatnik in forum Guitar Effects
    Last Post: 02-05-2015, 03:20 PM
  2. Line6 dl4 doesn't power up
    By Threlyn in forum Guitar Effects
    Last Post: 06-26-2010, 07:04 PM
  3. Replies: 10
    Last Post: 06-25-2010, 07:48 AM
  4. How to remove knobs from Line6 DL4????
    By Makauto in forum Guitar Effects
    Last Post: 03-27-2010, 07:22 PM
  5. Line6 DL4 in effects loop
    By hotthands in forum Music Electronics
    Last Post: 04-09-2008, 02:59 AM
