Does anybody have a schematic for a Bell and Howell Filmsound 399 Specialist model
https://elektrotanya.com/bell_howell.../download.html
That uses 6V6, but should be very similar.
You will want to lose the photo tube, and pull the power oscillator tube. Then go from there.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View Posthttps://elektrotanya.com/bell_howell.../download.html
I am not a mod guy, you are going to build a guitar amp circuit into this chassis. I know the projector circuit, and that phototube will react to light and make noise and affect the sound. And the oscillator is not needed and wastes power and heat.Education is what you're left with after you have forgotten what you have learned.
Just for your info, the EL84 versions of the filmosounds seem to be more desirable/valuable due to the "Bernie" amps, so keep that in mind if you are considering any major changes, such as output tube type.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
