Results 1 to 8 of 8
Thread: Boss DR-55 Problems
    Junior Member
    Dec 2017
    United Kingdom
    20
    Boss DR-55 Problems
    I have a boss DR-55 which only outputs the hats.
    I have already replaced the TC4011UBP with a (socketed) CD4011BE, but that made no difference.
    So, as I see it, either it's not "recording" my programming (although it goes through the motions), or none of the sounds other than hats are being produced.
    I am aware that there is a difference between the UB and B variants of the 4011, so I've ordered a CD4011UBE to try that.
    Apart from that, is there anything obvious I should be looking at.
    I have documented what I've done so far, here: https://synteknik.com/projects/curre...dr-55-project/
    Any help or suggestions gratefully received!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,947
    Received: 894/5
    You didn't mention it, but there is a scan of the service manual on your web site, which you linked. Kinda hazy but better than nothing.
    You get high hats but not the others? First the service manual has a good theory of operation section which explains it pretty well, plus the block diagram. But to isolate the problem, does the start/stop switch function? Does it make the hi hats stop and go? If so, then the flip flop is working, and that is your 4011. Also, does the tempo control affect the speed of the hi hats?
    As to the other sounds, they are all triggered from the memory chip, so are there output pulses from pins 12, 14, 16 of that IC? If not, then the voice circuits won't make sound.
    Since you do get hi hats, I assume the noise generator is working.
    If there are control pulses leaving the memory, look at each sound output transistor for signal. Those mostly have to run through the accent circuit, so if it has an issue, you might lose them.
    Someplace to start anyway.
    30,947
    Received: 894/5
    Junior Member
    Dec 2017
    United Kingdom
    20
    Thanks, Enzo!
    The start/stop works ok, and makes the hats start/stop. Tempo also works.
    I will check the outputs from the memory chip, then the accent circuit. Hopefully, I can do that with a simple multimeter..
    (The memory chip was already next on my hit list)
    Junior Member
    Dec 2017
    United Kingdom
    20
    Thanks! Much better..
    Junior Member
    Dec 2017
    United Kingdom
    20
    Ok. There's nothing on those pins. I get pulses on 3,4,5,6, and 17&20 on the other side. Looks like a dead chip?
    (I have some on order, but they'll take a while to get here..)
    Junior Member
    Dec 2017
    United Kingdom
    20
    Hmm. What if I poke say 5v into the voice circuits? Would I be able to test them that way? Not sure where to do that, though.. I just wanna hear the bloody kick and snare FFS!
    Junior Member
    Dec 2017
    United Kingdom
    20
    Quote Originally Posted by SynTeknik View Post
    I ordered another chip, from Holland, not China, and installed it last night. The DR-55 now works 100%. I've spent a really fun hour manually entering patterns. It's great!
    Many thanks to Enzo for the spot-on diagnostics.
    You can read the full story here:
    https://synteknik.com/projects/boss-...ent-tc5501p-2/
    The problem turned out to be two corroded legs on the TC5501P. How the hell? One of them snapped off on removal.. the replacement chip got stood on in transit. Looks like a size 9 doc marten print on the envelope, so I had to straighten the legs before insertion..
  1. Need advice fixing Boss Dr.55 drum machine
    By methodofcontrol in forum Music Electronics
    Last Post: 01-18-2018, 11:20 AM
  2. boss geb-7,cs-3 problems
    By bassjamma in forum Guitar Effects
    Last Post: 02-19-2010, 02:06 AM
  3. Boss GT-10 and Boss ME-50
    By rkohansk in forum Guitar Effects
    Last Post: 01-27-2010, 06:26 PM
  4. Problems on my Boss DD-3
    By MeTaLCaM in forum Guitar Effects
    Last Post: 11-18-2009, 10:20 PM
  5. Boss Me-8b and Boss GT-6B Repair Help
    By nbtone in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-28-2009, 09:59 PM
Tags for this Thread
