Results 1 to 33 of 33
Thread: Marshall JVM205 Cathode Follower Death, Sprial Filaments and Internet Mendacity
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Ugh. A JVM205 just came back to me. Again. The first time I saw it the CF tube was bad so it was replaced.
    Now in case you are not familiar with these the standby switch does kill not the HT. This means that when turn on from cold, the full 450V HT gets applied between the gird and cathode of V8b. So, I did what I do and added a neon between the grid and cathode to limit the grid current, replaced the tube with a 12AX7LPS spiral filament type and after other checking sent it home.
    And then it came back with the same tube dead. So, thinking maybe the spiral filament lore is true I fitted a non-spiral type and packed it off. After all I'd already done the neon grid protection trick so no need to worry about that, right? You guessed it, that one failed too.
    Hmm what about the heater cathode voltage? With a lack of actual data we turn to the Internet, naturally. Many forums will teach you that the heater cathode insulation fails when running since the cathode is about 165V and equally common is the statement to avoid spiral filament types as the insulation will fail due to not to be trusted new-fangled spiral technology. On the other hand I read somewhere that the Electro-Harmonix version was especially suitable for this task. The funny thing is that the data-sheets don't support this view. Here are the max heater to cathode limits from some datasheets. The LPS spiral filament is equal best at 200V. EH and Sovtek A/B/C all a dismal 100V.
    SOVTEK 12AX7LPS 200V
    SOVTEK 12AX7A/B/C 100V
    ELECRO-HARMONIX 100V
    GENELEX 12AX7 200V
    GENERAL ELECTRIC 12AX7 180V
    SVETLANA 200V
    TUNGSOL RI 180V
    We know to take contemporary data sheets not too literally so, suspecting that the insulation might be failing I set up a little test jig:
    The heater had volts applied and I monitored the half sine on the scope while raising the variac. Any failure would show as a flattening on the top of the waveform I tested the two 12AX7LPS and the 12AX7WC that had failed. I went all the way to 500V with no sign of failure. Same results with the heaters cold. Can you say surprised? Well that ruled out that failure mode.
    Time to look at these failures a different way so popped them into the curve tracer. By the way the "A" section is the DC coupled CF so it's easy to compare the two sections. The solid lines are section A and dashed are the B section.
    Also of note is then when running in the DC CF position you get a 40 to 50V drop from grid to cathode. I conclude from all this that the failure is to do with the grid. Presumably the incredibly fine wire is being destroyed during warm up by the current of <2mA, even with the neon from grid to cathode. By the way, ALL the datasheets specify a max grid to cathode voltage of zero. I think a current limit might have been more helpful.
    So, I've gone to a new strategy. The neon has now been replaced with a yellow LED with a forward voltage of 1.8V (measured, and because I have a pile left over from a different project) in series with a diode to protect the LED form reverse voltage. I did try just a diode but it caused too much flattening of the waveform. Another technique is so use a diode and a resistor in series. I wanted to have as low as an impedance as I could so that I why I went for the LED. Also changed the plate resistor from 220k to 330k to bring the cathode voltage to under 100V to be on the safe side. Marshall really wanted this to distort. The lower plate current available is somewhat mitigated by the increased plate to cathode voltage on the CF as that reduces the grid to cathode operating voltage. Interestingly the load line suggests this should be typically around zero. I'm seeing -0.5V, which is good:
    Here's a scope shot of the warm-up with a neon and with the LED and 330K plate resistor.
    Finally, when operating full tilt:
    So, I'm hoping this will be a permanent solution. Unless anyone has a better idea...
    PS: Maybe I wasn't clear so these are the methods I tried:
    4 Not allowed! Not allowed!
    582
    Received: 9/0
    My first problems with 12AX7 failing as CF started 10 years ago. The funny thing is they started exactly with EH. Some of them were dying after the first power up. Some of them later. Interestingly pieces from the previous batch were OK. Go figure. So after some digging in the net I learned that the problem was not specific to the EHs only and other brands would also fail as CF. After that I started raising the heaters to 70-80V just to be on the safe side and that cured the problem permanently.
    Then I asked myself the question how come Mesa DR is running the CF tube crazy voltages where the cathode to heater difference is more than 200V and I found out that they were using predominantly chinese tubes. I noticed the same thing with other companies as well. So if you need a tube that can withstand the abuse it looks like the chinese 12AX7 can handle it well.
    Concerning the protection I'm using the technique described here:
    The Valve Wizard
    2 Not allowed! Not allowed!
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 14/0
    I have never accessed tests of that type (thanks!) but my idea is that Sovtek LP / LPS and Tung Sol 12AX7 are not the ones indicated for that function. I discovered it the day that in a classic Marshall two consecutive LPS that had worked perfectly in tests on other functions failed suddenly in ten minutes. I speak about 14 years ago or more.
    With AC30 Vox CC series I consider relevant that they come equipped with two ECC83 Tung Sol in the first and third socket but in the second always includes a different one, usually chinese avoiding the Tung Sol in the CF.
    Mesa uses the same chinese 12Ax7 in CFs most of the time, but I have also seen units with CF equipped entirely with the model they use more frequently (Russian II) without problems. This tube is of Russian origin for sure but does not seem to correspond to any Russian model marketed by other distributors. It is not exactly WA, WB, WC, WXT, LP, LPS, Electro Harmonix or Tung Sol. The most similar is Electro Harmonix, but not identical.
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    In order to try to understand better what is going on, I've done more testing. Some pretty interesting results.
    First I tested the 12AX7LPS for grid current. This first plot used a signal generator. The grid/cathode behaves like a diode with zero forward voltage and 720 ohms in series. No sign of anything bad.
    Next, I used a power supply feeding the grid via a 1k resistor and noted the power supply voltage and the drop across the resistor. The objective was to see how much current I could feed into the grid before it failed. I ran increasing currents for about 10mins at each level and after each test ran it through the curve tracer at Vg=0 and Vg=-0.5 to see how it was doing. The reject tubes had only one bad section so I tested the good section. I was happy to sacrifice since they were bad already.
    This is at the start of testing. Solid line is the bad section and the dashed line is the section being tested.
    and this is at 8mA. Still OK. Still maintaining the 720 ohm slope. Note the bad section which just has the heater running seems to have fixed itself. More on that later.
    After 8mA, things started to go very non-linear, the grid current would fall and the grid to cathode voltage would increase i.e. the effective grid resistance was increasing. Eventually I left it with about 28V on the grid and just 2mA flowing, an effective resistance of 14K and left for 10mins. This is what we got. Notice the remarkable likeness to the bad section especially from the first curve trace in post #1. You can see that the section being tested has failed. This is somewhat supportive of grid current being the failure cause. It also meas that the LED + diode limit the grid to cathode voltage is a better strategy, not withstanding the other resistive current limiting in the circuit.
    Now, noting that what was the original bad section seemed to have miraculously fixed itself in the course of the tests, I ran the newly damaged section with 0.75mA with the heaters at 14.2 (as opposed to 12.6v) for 20mins and re-tested:
    We have recovered the newly made bad section. This tube now has both sections working. Why, I have no idea but it's very much like a build up of cathode interface resistance.
    Now taking Gregg and Pedro's anecdotal input on the Chinese 12AX7, I grabbed one and did the same to it. It would happily take 23.1 mA with the internal resistance staying steady at about 1.2K ohms.
    Final test on grid to cathode arcing. I applied 360V via a 4.7Meg to the grid, no heater of course. No sign of any problems. I'll redo at a higher voltage but I'll have to re-jig to get more volts.
    I think I might re-do the heater cathode insulation test to use DC rather than the half wave rectified voltage just in case it shows a different behavior due to a time effect.
    So, I was able to reproduce the failure but I had to use much higher currents (8mA) than can happen in the JVM205 where it's limited to about 1.8mA, Perhaps it's a time & repetition effect. Certainly not conclusive, but supportive data. So far, I have no evidence to support the heater-cathode insulation theory, other than anecdotal. Also it look like Pedro is on to something, the Chinese tubes are better in this regard.
    Coda:
    I re-did the heater cathode and grid to cathode tests at 600V Dc for > 1min. No problems at all. I'm not advocating that anyone use these as design guidelines, it was just to rule these out as failure mechanisms in this case. Clearly these tubes a a lot tougher than I thought.
    Lastly ,I did the just discovered heater tube recovery method on the last remaining damaged tube a 12AX7WC. That shows a 100% recovery too.
    If anyone knows what is really going on here, I sure would like to know.
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    I woke up this morning and it hit me. The problem is not grid current, but simply current. The design of the cathode determines the maximum current that can flow. This is thermal saturation. Once that is reached the cathode can be damaged due to the excessive current density(*) . I'll have to research the literature to find the exact details.
    Update:
    I tested the saturation current of the Sovteks by connecting the grid to the anode and sweeping up to 50V. They came out in a 25-35mA range. The Chinese one went all the way to the tester current limit of 400mA at 75V. So the problem is not thermal saturation since the current magnitudes are different but it's closely related. My guess is that as the grid is a spiral of fine wire close the the cathode, the current density on the cathode is excessive directly opposite the wires and so the cathode is being damaged.
    (*)Physical Electronics: Handbook of Vacuum Physics
    edited by A. H. Beck pg 233.
    5 Not allowed! Not allowed!
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    I guess not very many are interested in this. I spoke with Merlin about this. We agree that damage to the cathode during warmup is the probable cause. The cathode can only supply so much current as it warms, demand exceeds supply and the cathode is damaged. It's clear this damage can happen very quickly. Here is a suggestion of a mod to prevent this from happening.
    R1 senses the current through the first stage and when high enough turns FET M1 on. C1 prevents it turning on to quickly to avoid a thump and also give a some delay which helps mitigates an early turn on due a FET that happens to have a gate threshold at the the low end of the range.
    3 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,664
    Received: 588/1
    Why doesn't this happen to every JVM205 then?
    1 Not allowed! Not allowed!
    Nov 2013
    148
    Received: 23/1
    Given: 2/0
    this happens mostly to russian tubes,if you have a JJ or good chinese tube it won't happen so easily,best thing would be to elevate the voltage reference of filaments to at least 80V.
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    It depends on the tube. The Electro-Harmonix types that I tested have about 1/4 or less the emission at new than the Chinese. The warm up characteristics will have an effect too. I started looking into this after seeing many failures in Marshall amps in which the B+ is always on.
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by alexradium View Post
    Agree up to a point. In my tests I proved that heater to cathode insulation is not the the issue as I put 600V across them without it breaking down. It was clear form the curve tracing that the emission had collapsed.
    582
    Received: 9/0
    IMO this is not a realistic mod. It needs to be quick and dirty like the one with the 47k resistor and 1N4007. Next quick (if the scheamtic allows) elevate heaters (or just the CF one) up to 70-80V, even 90V.
  12. #12
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by Gregg View Post
    I agree Greg. This would not be practical as a mod and I didn't intend it as such. It's just a suggestion for one way of dealing with the issue.
    PS: I have no evidence whatsoever that elevating the heaters does any good - see earlier tests.
  13. #13
    Junior Member
    Feb 2010
    18
    Received: 2/0
    Hi,
    Looking at schematic : R81 and R83 form a voltage divider that elevate the heaters to 67V DC.
    Do measurements confirm this ?
  14. #14
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    Hi guys. I found this thread with a Google search and decided to become a member on the strength of it. I'm a JVM205H user with a real interest in this very subject after I came across Merlin's Valve Wizard site and his description of it there a good while back. I have implemented the resistor+diode fix but I am now intrigued by your LED+diode version. Also by the fact that you don't think the evidence shows that the mechanism is a feature of the grid/cathode overvoltage at switch on.
    I can confirm one fact straight away. In the JVM series Marshall have definitely already implemented lifting of the heater voltage by what must be around 60V. This is created direct from the initial Preamp HT voltage across a divider made with resistors of 82k and 470k, (400V -> 59.5V, 450V -> 67V).
    Seeing what you have tested and found here is really interesting and I take my hat off to your methodology. Sadly NickB seems to have been worried that no one is interested, well I for one am intrigued. Has there been any progress on this subject since the post before this?
    Edit: It does occur to me that the exploratory tests you did on grid current with your PSU and 1k resistor could be set up to simulate the real world conditions of the DCCF fed from the 220k anode resistor of the previous gain stage with the 47k cathode resistor of the CF itself, as that would perhaps relate to the real current limits within the grid circuitry. Or is that not relevant?
    Last edited by bordonbert; 07-18-2018 at 08:12 PM. Reason: Reread and came up with an idea from original data
  15. #15
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by bordonbert View Post
    Welcome and thanks for the interest. I could modify the test set up to mimic the actual map but I prefer have the controlled conditions. I remain convinced that it is the excessive cathode current that damages the tube. it is (was) easily demonstrated that heater to cathode insulation breakdown is not the problem.
    The easy fix seems to be to use Chinese tubes. The Sovtek ones that caused me so much pain are to be avoided.
  16. #16
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    I can understand your desire to keep to controlled conditions for testing purposes but I'm confused as to how the real life situation within the JVM then relates to that. Surely the gain stage 220k anode resistor has a limiting action on the current available to sink into the grid (<2mA) and the 47k DCCF cathode resistor further limits it. Do they not prevent your most severe overcurrent conditions of >8mA from occurring in the real amp?
  17. #17
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    I'm not sure what has happened here Nick. I did reply to this a fair few days ago now but it seems to have vanished into the aether, (how many of you guys are old enough to remember that one?)
    I can certainly accept your findings that cathode/heater overvoltage is not the killer I imagined it would be, neither is grid/cathode arcing a problem within our voltage range. It's good to have actual practical results of sound real world testing to give up on those two issues and sleep at nights again.
    I think I can understand that your results also show that it is current which is the deleterious factor with a crucial point being reached around 8mA but I can't see the mechanism by which that current in the grid is actually reached. How is it that the grid current is not limited to around 1.25mA by the preceding anode resistor of 220k and its own cathode resistor of 47k. With the grid/cathode forward biased and acting like a diode surely they limit the current as the only source of grid current is from the HT line through the grid to ground via the two resistors. I thought your results showed that the crucial level for damage was about 8mA or have I missed something there?
  18. #18
    Apr 2010
    Burbank, CA
    831
    Received: 96/0
    Given: 244/0
    Nick, you've outdone yourself with the engineering, testing and following the findings to reveal some amazing results. I haven't yet come upon any of the JVM series in our inventory, but do see there are a pair of JVM410's that haven't ever been into the shop. As I'm presently doing preventative maintenance on our rental inventory, all of your work here very much interests me. I'm also curious as to the tube curve tracer you're using. I'm still loosely in the market for one, though being poor at present, I tend to cobble things together that I've obtained over the years to do new tasks. Never did have the funds to invest in proper semiconductor curve tracers, let alone one for tubes.
    Excellent thread and contribution from all of ya!!
  19. #19
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    I'm really not sure what is going on here but I have replied to this thread twice in the last 10 days and both posts have vanished into the aether. I get the message that as a newbie my reply must be passed as wholesome first but neither has appeared after 10 days. I can't help thinking they have somehow gone astray internally. I am trying again as there is something I really want sorted out in my own mind in order to fully understand this problem and its solution.
    Like Nevetslab I am highly impressed with the info that has been offered here. Of course using a Chinese ECC83 is a working solution and the way to go with a simple follower but for me to just accept and apply that without getting to grips with the entire problem and its causes seems a bit of a fudge to me. It seems the ultimate conclusion is that it is the current which is the killer at levels over 8mA and not the exceeding of any maximum voltage levels. I can't however see how that level of current can occur in the real life JVM circuit. Originally I assumed you meant the grid current with the grid/cathode diode forward biased but then I realised from your description of the cathode involvement you would more likely mean the total cathode current. The DCCF has a cathode resistor of 47k. Surely that alone is enough to limit the total current through the valve to safe levels even under fault conditions at startup?
    Is the damaging state under fault conditions such that the entire HT is put across the cathode resistor? This would assume there is no grid current being passed which would drop the grid voltage via the anode resistor either reverse biasing the grid/cathode again or dropping the cathode voltage due to follower action and reducing the anode current contribution. All states I can imagine result in reduced total current through the valve.
    What am I missing here?
    (EDIT: This time it seems to have shown up. Sorry Nickb, as I said I did reply to you earlier.)
  20. #20
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Success
    Compare it to using a 20A power transistors instead of a 5A one in an application that needs 4.9A. So fitting an appropriately rated part is a reasonable solution. Also, practically speaking, a solution is needed that can be easily fitted to the PCB.
    As far as getting to grips with the entire failure mode, part of the problem with doing that is time. I seldom get enough to indulge in this kind of investigations. Also, to be conclusive, I think I'd need an electron microscope to examine the (suspected damaged) cathode.
    The figure of 8mA was for a fully heated cathode. For one that is n the process of heating I would expect the figure to be lower and vary from tube to tube.
    I don't think you are missing anything. I suspect the sum of grid current with localized current density effects and anode current is important. Experiments need to designed to prove it one way or another and be beyond the scope of a home lab. However I am confident that based on the testing I have done that heater-cathode insulation breakdown is not the cause.
  21. #21
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by nevetslab View Post
    Thanks for the kind words
    I used a modified uTracer
    I have modified mine for a wider grid voltage range and a 400mA max current. I also wrote a new GUI that was more suited to my needs.
    The repeated failure of Sovtek 12AX7 in this function has been a recurrent nightmare for me as that was the only brand I stocked. I now stock Chinese ones for use cathode follower functions. Time will tell but so far so good.
  22. #22
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    The figure of 8mA was for a fully heated cathode. For one that is in the process of heating I would expect the figure to be lower and vary from tube to tube.
    AHA! Of course, that just never occurred to me doing all my work in solid state. And I think that point makes sense of the process now for me.
    I do appreciate what you say about limited time and resources to throw at the problem and, for my money, you have done some pretty spot on investigatory work Nickb. It should have been enough that you have actually shown the grid/cathode and cathode/heater breakdown voltages are not the bÍtes noires they have been thought to be. Aspects like the damage repairing process are also an unexpected bonus for me.
    If you ever start passing the hat to fund that electron microscope...
  23. #23
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,111
    Received: 49/0
    Given: 923/0
    Quote Originally Posted by nickb View Post
    Very interested, thanks for posting details of your research. A friend from high school, that Ive been able to connect with through Facebook (guitar player, semi retired electronics guy of about 35 years, and Marshall enthusiast) sent a bunch of notes about certain Marshall amp CF problems, and difficult time finding tubes for CF that won't blow. It wasn't a JVM205 though, will find out
    Nick, any chance you could mention which brand(s) CHinese tubes you've had success with?
    Thanks!
    MP
  24. #24
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    Odd again! Just tried to thumbs up your post Mike but it looks to me as though it may have done something with the thumbs down instead. If so it's an accident, my apologies. (EDIT: Nope, AOK, it's just me not understanding the system again.)
    I'd be interested in knowing this too. One thing I am aware of is the fact that if you stick a Chinese made model in there it can then place one of its triodes in a gain stage position which many people won't like. I have a Hughes & Kettner GM36 which is in that category. For my money, I've never found much difference if any between makes in guitar amps and I recently found what, to me, is proof online that there is little difference. And it was actually masquerading as proof there is a major difference!
  25. #25
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by mikepukmel View Post
    Thanks!
    MP
    Mike, they were Shuguang.
  26. #26
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,111
    Received: 49/0
    Given: 923/0
    Thanks Nick. This is huge!
  27. #27
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    This is not to try to get Nickb to do any more work on this issue, , it's just to do with its practical effect.
    If we have a generic 12AX7 in the DCCF slot and it does succumb to this sort of problem what effect does that have on the sound of the amp? It's only a follower after all, 100% feedback should cope with a lot before it becomes blatantly obvious that something is wrong though the specific DCCF distortion mechanism could no doubt be affected. Does anyone have a first hand knowledge of this problem in a working amp and can suggest what would be heard?
    I do have a JVM205H which has a problem of sounding a bit lacking in brightness and it definitely becomes more dull after about half an hour of playing. It has had a complete new set of valves fairly recently, probably about 6 weeks ago, which improved it at the time but I'm sure it is slipping back again into its dullness. I'm wondering if this could be what I'm suffering from. I have a Shuguang to drop in there but it has just arrived and I haven't had a chance to do that yet. I'm trying to get it in place for a gig tonight though I shouldn't really make a change so close to live work.
    Any info available?
  28. #28
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Any info available?
    Those that had failed sounded very quiet and distorted. I can only say that all two types of Sovteks I tired failed and that good RCA, GE and Sino did not. I didn't try anything else.
    Wait till your new tube arrives and try it out then we'll know if that is the issue or not. You probably should start a new thread if you want to discuss since it's a different subject.
  29. #29
    Junior Member
    Jul 2018
    14
    Received: 9/0
    Given: 2/0
    Will do Nick. Thanks for pointing that out.
  30. #30
    Lifetime Member
    4,273
    Received: 56/0
    As one more extension to the MOSFET Heresies, I could point out that MOSFETs do not have heaters, and they make a dandy-fine DC follower.
    See post here and articles on MOSFET Heresies at geofex.com.
  31. #31
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    Not wanting to argue with the author, but I don't see follies as being the same as heresies.
    http://www.geofex.com/Article_Folder...osfetfolly.htm
  32. #32
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    Quote Originally Posted by R.G. View Post
    ..except that, at least in this case, the heater was not the problem. Besides, where's the joy in gathering around a cheerless, non glowing, stone-hearted MOSFET on cold Winter's day?
    I fear we digress. That never happens around here....
  33. #33
    582
    Received: 9/0
    In a Marshall type amp the CF is not just a "follower". As very well known it distorts in a certain way which is part of "that" tone. An FX loop send stage is another story.
    MOSFETs are nice to play with however they don't distort the same way as a tube CF. In order to make a MOSFET distort like a tube CF it needs some additional tweaking. I think I posted this article somewhere but here it is again:
    http://media.amtelectronics.com/tver...mt-warm-stone/
    Another one (in Russian) with plenty of scope pics:
    http://milas.spb.ru/~kmg/irf.html
  1. Replies: 18
    Last Post: 03-28-2014, 02:06 PM
  2. Replies: 0
    Last Post: 03-25-2014, 09:51 AM
  3. Cathode follower and heater to cathode voltage? 12AX7
    By CoffeeTones in forum Guitar Amps
    Last Post: 03-17-2013, 10:15 PM
  4. Cathode follower/DC filaments - issues?
    By EFK in forum Mods & Tweaks
    Last Post: 03-01-2010, 11:26 AM
  5. Cathode follower cathode resistor question
    By Mark Buckingham in forum Theory & Design
    Last Post: 10-10-2006, 12:12 AM
