I have an email out to Peavey Parts but wanted to see if you guys have ever had to replace these and know where to find them aftermarket. They appear to be riveted to a rather long PCB mounted extension. Never seen one like this.
Peavey CS800 banana binding post
Originally posted by tdlunsfo View PostI have an email out to Peavey Parts but wanted to see if you guys have ever had to replace these and know where to find them aftermarket. They appear to be riveted to a rather long PCB mounted extension. Never seen one like this.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Not sure how you would rivet a binding pot, but they used soldered in ones for years. Yours look like this?:
https://www.amazon.com/Binding-Post-.../dp/B00E1P3VH4
https://www.tubesandmore.com/product...eavey-pc-mount
That is just two sources, and I am sure Peavey has them as well. You have to CALL PV to place parts orders.
Really old CS series amps used the posts with the brass screw down the middle, it mounted through holes in the PCB or just wires, then a nut tightened the connection.Education is what you're left with after you have forgotten what you have learned.
