I have the normal one and was about to buy the ER version then I found out he stop making them. Its really unfortunate. Any other similar gauss meters out there?
Spin Doctor type gauss meters?
This topic is closed.
Does ER means "extended range"? The meter I designed can measure values up to 1690 Gs. I was wrong thinking that it can be easily modified by replacing the Hall sensor. The only sensor that I found out for the extended range is AD22151, which is in a different package than I used. So I would need to redesign the PC board. Have you got the schematic of your meter? I'm curious how the gain if the Hall sensor was switched. With MOSFET transistors or in some other way?
PS1: the value 1690 Gs seems to cover most of the pickup types I have seen (the highest value I measured was 1100 Gs). What type of pickups require extended range? Or you want to measure neodymium magnets?
PS2: is neodymium N52 used for guitar pickups?
Mark
Hey Mark,
yea ER means extended range. http://gravitastech.weebly.com/spin-doctor-er.html
I was looking to get the ER version because I mixed up a bunch on neodymium magnets and I need to know their gauss value.
Originally posted by MarkusBass View PostThanks for the info. So the ER version had a fixed range 25000 Gs. It's suitable for neodymium magnets but for pickups you loose accuracy. This can be done but requires a redesign of the PC board.
Yours very truly,
Pepe
Milano, ItalyPepe aka Lt. Kojak
Milano, Italy
Originally posted by LtKojak View PostThe v. 1.1 looks pretty good. I only need to measure alnico bars, so no need for extended range for me. Let me know when you're open for business.
Pepe
Milano, Italy
It's a pity that we couldn't meet in Milan.
Have you seen this photo?
It was made in Milan - pickups with alnico magnets. I was wondering whether these were your pickups.
Mark
[ATTACH=CONFIG]52548[/ATTACH]
Mark
Having said that, I've been known for modding, repairing and re-winding a fair amount here and there, then and now...Pepe aka Lt. Kojak
Milano, Italy
Finally I have 7 meters ready. One of them has black enclosure. I have also 2 prototypes but I need to update their software - there are minor differences between the prototypes and the final version. I think I need two weeks to do it and they will be also available (and they will be cheaper). The main difference between the prototype and the final version is the tip of the meter (this can be corrected with a dremel tool) and lack of the charging status LED. The rest will work in exactly the same way.
Originally posted by MarkusBass View PostFinally I have 7 meters ready. One of them has black enclosure. I have also 2 prototypes but I need to update their software - there are minor differences between the prototypes and the final version. I think I need two weeks to do it and they will be also available (and they will be cheaper). The main difference between the prototype and the final version is the tip of the meter (this can be corrected with a dremel tool) and lack of the charging status LED. The rest will work in exactly the same way.
[ATTACH=CONFIG]52884[/ATTACH]
Originally posted by Rog_B View PostGreat job! They look awesome. Do you think you could make a little You Tube video of one in action, showing the various functions? That would be really helpful!
Mark
I've got few questions about features of the meter. Here they are:
- Range +/- 1670 Gs. Over (and below) this value the meter displays "OVER" text
- The polarity of the magnetic field is displayed as letter "N" or "S"
- 0.96" "OLED display (good visibility in dark rooms)
- Li-Po 320 mAh rechargeable battery - can be recharged with typical 5V phone power supply (with micro USB plug)
- auto power off - after 1 minute of not in use
- auto zero set at startup
- tactile push buttons: POWER, MODE, START/STOP
- 3 modes: CURRENT (the actual value of the magnetic field), AVERAGE (the average value of the magnetic field - can be stopped/restarted with START/STOP button) and PEAK (the maximum value - can be reset with the START/STOP button)
- 200 samples per second in all modes
- ABS enclosure (grey or black)
- graphical representation of the battery displayed on the screen
- when USB charger is connected, USB symbol displayed on the screen
- charging status LED
- low power consumption (10mA in active mode, 70uA in sleep mode)
Since the meter is never switched off (it only enters sleep mode) there is also a RESET button but I never had to use it.
MarkLast edited by MarkusBass; 03-13-2019, 12:24 PM.
Originally posted by MarkusBass View PostI've got few questions about features of the meter. Here they are:
Mark
I can’t PM yet as I’ve not posted since joining a while back (will have to fix that), but I’d like to put my name down for one of these if possible. Preferably in black. :-)
Best regards,
TimTim
Originally posted by Timmy! View PostI can’t PM yet as I’ve not posted since joining a while back
Mark
