Results 1 to 6 of 6
Thread: Marshall origin series 20w....why 20?
    Old Timer daz's Avatar
    Jan 2007
    2,600
    Received: 10/0
    15
    What i'm asking in the title is, does anyone know why the origin 20 watt amp has 20 watts with 2 El34's vs the origin 50 watter with the same pair of EL34s? Small iron or low plate V ? Just curious....
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,308
    Received: 2,307/4
    Given: 2,665/0
    30
    Quote Originally Posted by daz View Post
    Likely both. I've never had one open and it's too soon for schematics to be found on line.
    Old Timer
    Chill-Ville, VA
    3,167
    Received: 672/6
    Given: 1,298/9
    18
    Low volts, cathode bias... And because everyone is a sissy nowadays and a 22W Deluxe Reverb os "too loud & you're drowning every one out & & & wha wha wha!" So 20W is 2 less, innit?
    I'll see myself out now.
    Jusrin
    1 Not allowed! Not allowed!
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,589
    Received: 267/1
    Given: 220/0
    16
    The amp output power depends on the working class amp (A, AB, B), anode voltage and load resistance (Raa)
    https://www.slideshare.net/ValveData/valve-amplifier-design-el34-6ca7-data-mullard-valves
    https://image.slidesharecdn.com/el34-120607235944-phpapp02/95/valve-amplifier-design-el34-6ca7-data-mullard-valves-2-728.jpg?cb=1339113885
    Here it is best to see how at the same anode voltage, the output power changes depending on the class of work in which the amplifier works and the load ressistance (Raa)
    If anode voltage and load ressistance (Raa) is known, it is easy to determine the output power.
    Load ressistance (Raa) is calculated by measuring ratio output transformer.
    http://www.marshallforum.com/threads/origin-20-head-gut-shots.101569/
    Origin 20 Head Gut Shots!!!!
    May 2007
    pacific north west
    15,308
    Received: 2,307/4
    Given: 2,665/0
    30
    Quote Originally Posted by Justin Thomas View Post
    Jusrin
    I got yer back Jusrin My personal amp is the prototype I built for DMS. It's a pair of el84's and it's designed to run balls out WITHOUT POWER SCALING. I admit that I have an attenuator (because I'm married ) but I think that for the feel and vibe of using a cranked guitar amp that the 20 or so cranked watts (only 15 clean) this thing makes is the minimum even in small spaces for getting the acoustic feedback inherent to "that" sound and feel. I literally sit in a chair about ten feet away from the amp with it facing me whenever I get to let it rip. I have Celestion V30 in this amp (combo) and a sealed 2x12 with a pair of G12H30 Anni's (that I prefer) so these are fairly efficient speakers. I still think you'd need to mic it for a small bump for live use. 20W is MINIMUM home practice wattage IMHO.
    Old Timer
    Chill-Ville, VA
    3,167
    Received: 672/6
    Given: 1,298/9
    18
    Ensuring domestic tranquility is one thing. Gigging is another. Your sin of attenuation is absolved.
    Jusrin
    2 Not allowed! Not allowed!
  1. Cabs for a Marshall Origin 20
    By Tqi in forum Guitar Amps
    Last Post: 05-16-2018, 10:07 PM
  2. Marshall MG Series?
    By olddawg in forum Theory & Design
    Last Post: 12-06-2015, 09:44 PM
  3. Origin of the 6L6GC?
    By Rhodesplyr in forum Tubes (Valves)
    Last Post: 12-12-2013, 12:55 AM
  4. CandyRush-Music.com - Desa Systems - Origin of Us
    By candyrush in forum Music Electronics
    Last Post: 04-27-2011, 05:16 PM
  5. Marshall MA series
    By strato56 in forum Schematic Requests
    Last Post: 05-23-2010, 10:57 AM
