Results 1 to 8 of 8
Thread: Fender AB763 Vibrato Channel Square Wave Frequency Testing
    Dec 2008
    834
    Received: 50/1
    Given: 24/1
    12
    A friend of mine with a BF Super Reverb was asking me about the Vibrato Channel of his amp because he doesn't like it as much as the Normal Channel. As far as I can tell, there's nothing wrong with it.
    Since then, I've tested a few AB763 Vibrato Channels with a square wave, and though I can tweak the Normal Channel tone controls for relatively flat response, I can't dial in flat response on the Vibrato Channel. There always appears to be some treble boost on the Vibrato Channel, a spike at the front of the square wave. It's not ringing, but it's not flat.
    By reading the circuit, you can see why it's not flat. I was just hoping someone else has seen the same thing to confirm my result -- that the AB763 Vibrato Channel is a lot more "colored" than the Normal Channel.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,890
    Received: 1,786/21
    Given: 1,462/0
    14
    Yes, the reverb/dry mix circuit where dry signal is extracted from the second preamp stage through 3M3 paralleled with 10 pF, you'd have to expect a little hi frequency peaking there. You could remove the 10 pF cap, or reduce it for a flatter response. Or increase it for more zing if that's your thing.
    Try as you might, there's always going to be a difference because of that mix stage plus the makeup gain stage - one of V4's triodes - that follows it. C'est la vie. Somehow Fender has millions of fans in spite of these quirks.
    1 Not allowed! Not allowed!
    Enjoy. Every. Sandwich.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,505
    Received: 2,543/7
    57
    Yep, nothing wrong with it. At a local taern, there are two nice waitresses. Nothing wrong with either one, yet I prefer one of them over the other. What do do, what to do...?
    2 Not allowed! Not allowed!
    Nov 2013
    345
    Received: 130/11
    Given: 45/0
    7
    another thing that is peculiar to that channel is the vibrato pot always attached to the third stage,if you disconnect that probably you will get a fuller sound.
    But Fender ab763 are not flat by default,for a reason,and you don't play square waves,or at least you play distortion pedals with big low pass filters and no bright cap engaged.
    Dec 2009
    Devon, UK
    3,815
    Received: 947/1
    Given: 694/1
    14
    All the above plus don't forget about the huge effect the speaker has on the waveform. I'll bet the output of that doesn't look very square.
    Supporting Member
    Staffordshire UK
    3,883
    Received: 599/1
    Given: 557/2
    19
    If that 10pF cap was on a switch and its effect could easily be ABd, I suspect that most would switch it off.
    Supporting Member
    Mar 2018
    Germany
    3,243
    Received: 2,360/1
    Given: 1,343/2
    8
    I think that 10pF cap is there to compensate for the treble loss somewhere above 6kHz caused by the Miller capacitance of V4b (roughly 100pF). Its value might be a little high, but I like the effect.
    - Own Opinions Only -
    Dec 2008
    834
    Received: 50/1
    Given: 24/1
    12
    Quote Originally Posted by alexradium View Post
    Quite true, but square waves are a good diagnostic tool for determining whether or not an audio circuit has flat frequency response or not or if it's exhibiting any other problems like ringing, etc... In this case, it's a good way to observe objectively that, yes, one circuit is changing the shape of the input waveform more than the other in a way that's visible on a scope.
    I just want to be able to tell this guy with confidence, "Yes, they all sound like that. You have indeed noticed a difference between the Normal and Vibrato Channels, but there's nothing wrong with your amp."
  1. Square wave testing guitar amp OT
    By GainFreak in forum Theory & Design
    Last Post: 04-27-2018, 09:00 PM
  2. 70's fender deluxe reverb hiss in vibrato channel
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-17-2012, 12:51 AM
  3. Fender Bandmaster AB763 Vibrato problem
    By StratTone in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-22-2008, 05:03 PM
  4. Fender M80 - square wave generator!
    By Ron in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-05-2007, 12:57 AM
  5. Building a Univox Square Wave Clone
    By beastmaster in forum Guitar Effects
    Last Post: 03-23-2007, 08:16 PM
