IME the main thing to quieting Down an Amp is Smaller Speakers.
Example Plug a 50 watt turned down amp into a 10 inch speaker.
Then plug the same amp turned down into a 4x12 Cab.
At the same low level the 4x12 will be much louder probably because of the amount of air moved.
My 50 watt marshall even with 2 Master Vol. is hard to play at a low level into the 4x12 Cab.
It is much more controllable into the single 10 Inch.
So if You are playing in a small apartment do low wattage, and small speakers.
Like a single 8 or 10 inch speaker.
B_T
B_T
