Anyone familiar with Dumble amp?
  • #61
    Originally posted by Alan0354 View Post
    Ha ha, I am building amp one by one, and yes, my wife brought up this very problem up just a few days ago. If I keep building it, I would have too many amps!!! But in a way, I like it that way, then I can see my progress.
    *chuckles and nods* Yeah, that's kinda why I asked...it'd make it a whole lot easier for you to be able to honestly compare what you liked about the circuit you built in 'J' test build, vs 'D' test build, vs etc. Rather than trying to rely on memory/notes of what it was. But of course, that's where storage becomes an issue if you hold onto everything...
    I kinda mentioned in a previous thread what my ideal amp would be, but honestly, don't think it's even remotely "possible". At least, not by anyone 'sane' and not within a traditional head-style chassis.
    It would be a complete BEAST to try and move anyways -I figure the head alone would be somewhat around the weight of my MkIII Simul that's loaded with the EVM-12L (if not MORE than).
    [Approx. 100+lbs for those who haven't had the "joy" of hefting one.]
    But trying to get a BF Fender Del.Rev. or Vibrolux clean channel (w-tube rectifier), and the lead channel of a MKIII, and having the option to switch not only preamps on the fly (live), but having the option to switch outputs from 6L6 (in D.R./Vib. mode) to EL34 while in Lead mode...it would have to have two seperate PT's, two seperate OT's, and then two seperate rows of preamp tubes. Literally two amps in one.
    LOVE the 'American' cleans (as you call them) but the Brit dirt just does something that makes the fur fly!! I guess that's what made me fall in love with the MkIII to start with, as it's the closest thing I've found to my ideal amp. The warmth of the 6L6 and the bite of the EL34 just seem perfectly matched to me.
    /pipe dream off (but hey...can't say I don't dream big!) lol
    Most 'traditional' players would probably consider that quite an eclectic mix in tastes. But that comes from loving so many different styles of music. I just think that so many "clean sounds" in metal suck. Anyways, this is my idea of the 'perfect' touch-sensitive universal amp for someone who digs many styles. It's still marinating in the back of my mind...perhaps one of these days I'll get the courage to try and see it through (or at least something in the spirit of it). I do know, that the older I get, the more I hate even lugging around the MkIII.
    Anyways, thanks for humoring me, and sorry for the minor derail.
    Start simple...then go deep!
    "EL84's are the bitches of guitar amp design." Chuck H
    "How could they know back in 1980-whatever that there'd come a time when it was easier to find the wreck of the Titanic than find another SAD1024?" -Mark Hammer
    • #62
      It's actually not a pipe dream to be able to switch tubes on the fly. I actually look into this as I have 4 socket in the Marshall. I even consider 6V6 and EL34 switch. I was considering switching Zener diode string in to lower the +B 40V when using the 6V6. Then a switch /relay for bias voltage. Then another relay to ground one or the other cathode of the power tubes. If you only switch between 6L6 and EL34, I don't think you even need the zeners to drop the +B. So you only need two relays to switch the cathode and the bias voltage only.
      I decide not to do it because I have VVR and more important.......I am lazy!!!! It's more complicate to do tube switching with VVR.
      I did it in the Pro Reverb, I have a switch, but I have to hand swapping the power tubes between 6V6 and 6L6 as I don't have extra socket.
      I never consider switching preamp, so I don't have anything to say. Ha ha, I have 3 preamps in my Bassman, I just use a A/B box to switch.
