Power transformer for a SLM Crate VC20 tube amp.....
  • #16
    aimeovaldi: I have PM'ed you regarding the transformer that you ordered as I don't think that it will work for this amp.
    The correct one would be an Edcor XPWR152. I hope that you can change the order for the correct one.
    • #17
      Hope the same.
      The one first suggested and ordered is basically a *Preamp* PT, will feed no realistic power amp.
      Guess it's not too late since they have to be custom built and specified "6 weeks" .
      You'll have to pay a little extra for it; $43.21 list price vs. $37.03 .
      • #18
        I have placed a call to Edcor regarding a change in the order, all lines were busy, I left a message and will continue to attempt contact. Hopefully they can amend the order, but if not, it was only 55.00. I still appreciate the help and that you responded to correct the info.
        • #19
          Edcor called me back, they have no problem changing the order, and it is only 7.12 more. They are great to work with. So all is good and I should have the transformer in about 6 weeks. I will keep all posted as I go. Thanks again.
          • #20
            I'm glad that you were able to get it straightened out and again I apologize for the error.
            Because the filament winding lacks a center tap, you will need to add two 100 ohm, 1/2 watt resistors to the circuit to create a ground reference for the heater circuit.
            • #21
              Well I received the transformer and the amp is at the tech as I type. Hope all goes well and she is up and running soon.
              • #22
                Cool, good luck.
                Just curious, how long did it take Edcor to actually make and deliver the transformer?
                It might be useful for others.
                • #23
                  The total time was about 3 weeks from order to delivery. Pretty quick in my opinion.
                  • #24
                    Thanks.
                    It's always useful to be able to match "promises" to "reality" ...which in this case was excellent.
                    6 weeks promised vs. 3 weeks actual delivery time?
                    Way to go Edcor !!!!
                    • #25
                      Is the winding for the heaters on the original transformer actually 12.6 volts center-tapped?
                      • #26
                        According to the schematic it is 6.3 vac center tapped.
