The headline says it all. I have had this amp to 2 techs ... to discover and fix an overall RATTLE from the amp (somewhere) which is worse when hitting an open A. And - a very present MUSHIENESS at volumes above 3 or 4.
I tried to isolate the speaker by running the amp through a different cab - and it was much better ...
DOES IT MAKE SENSE TO ...
>>> switch-out the existing CELESTION speaker with an EMINENCE LEGEND 1258 ... 12" Guitar Speaker 75W 8 Ohm
>>> switch-out the existing output and pre-amp tubes for a cleaner - tighter - more focused sound.
thanks for your advice.
