Ok..I installed a new TR5 BC184 and IC10 PIC16F57. Still no sounds. I then removed the new TR5. Just like before...with the TR5 out, the voltage at it's base hole is 4.37v with the speaker plugged in. 0 with the speaker unplugged. With the speaker in, the 4.37v stays the same whether the STAND-BY switch is on or off.
Is 4.37v enough to run the TR5? I can see the test wave at the ecc83 as before.
Mike
Mike
