Hartke A70 Bass Amp troubleshoot
  • #31
    Originally posted by Fabrizio View Post
    But: At J10a (Speacker connection) I have 44 V across + and -.
    Not clear. Is the output DCV positive or negative wrt amp ground?
    I checked transformer and I have +34v from black to blue1 and +34v from black to blue2.
    Why +34V? Should be ACV.
    Voltage at D12 is +44.8v and at D13 is -44.8v. So it looks like the main rails are OK , I believe?
    Supply looks good.
    • #32
      Not clear. Is the output DCV positive or negative wrt amp ground? yes dcv is +44v between junction 1 and 2 on J10a (see the diagram)
      Why +34V? Should be ACV. yes it is ACV and 34v
      • #33
        Please Help if anyone can , I am trying to trouble shoot this amp again. I have voltage across the speaker connection.
        • #34
          The main rail voltages look good.
          The original issue was negative voltage on the output.
          And now you have a positive voltage.
          What changed?
          • #35
            What changed?
            No negative Voltage
            DCV is +45v between junction 1 and 2 on J10a (see the diagram)
            casinolevant levant casino
